Tjm compressor and bracket for engine bay
parb
1:02 PM
Silicon Valley, CA, USA
What do you think of both the compressor (tjm pro single stage) and the mounting location?
I think I like the idea of getting the compressor out of the cabin. I'm not super sold on that style switch but that I can change. I worry that the switch isn't made for the rough environment that exists in an engine bay. But I think I can find a better switch if I need to.
Thoughts on this anyone?
It is well known, compressors run very hot ARB or TJM. Therefore they wont necessarily last under the bonnet (depending upon ones use case).
In the Grenadier Diesel or petrol engine bay, theres no room. Becuase of the heat especially in Australia, best to keep the engine bay as open as possible. I am having the hydraulic jack plate re-made so I can bolt in the TJM compressor (just fits upright). The covers all removed, plenty of air cuirculation as the TJM Vehicle Mount Compressor has a 100% Duty Cycle, with the outlet and switch mounted in the front panel of the new draw system. The Factory Jack mount is not practical anyway once the rear cargo area is full.
I have heard that but I think so many people run ARB in engine bays that is a non issue. Especially since the hood would be open and the pump has a fan on it. I am not driving around and using compressor at the same time. Also i am doing this for one vehicle. All told i expect 8-10 minutes total to air my tires.
If the pump has a shorter life by a few years it is cheap to replace. The convenience is more important to me. The pump location is very roomy. There is a big void there. I think this will last many many years. Also not as hot where i am compared to Australia.
I am thinking a NATO plug conversion to one of the portable generators and just plugging in the rear to run for all 4 tires is what I am going to do. I dont like having them in vehicle or under hood. Ran a CO2 tank for years on my Land Cruisers, FJC and 100 series without issue...and one tank lasted me for a week trip in Uwharrie with daily lowering/raising of tire pressures. If nothing else will mount my tank rack and do that on this vehicle too for time being.
Happy with mine so far. Aside from an electrical gremlin that sorted itself out (it seems), it has worked as expected.
It should be noted that the engine bay location used by the CA Tuned bracket is occupied by other equipment on the diesel trucks, so petrol folks only.
I’m very happy with mine using the CA Tuned bracket. I re-did the wiring to simplify it, way too many wires (used a local ground on the body). I installed it about 6 months ago!
Ok, i am having that Issue with the harness. Was thinking i need to redo it. Where did you guys get the acc power for the relay?
Was not sure if i cut and use marine butt splices or just redo all the terminations as well. I would have to order new waterproof connectors
I kept all of the original connectors and just used the self-soldering/ heat-shrink wire connectors to shorten or lengthen as necessary. I drew power straight off the jump location (with an in-line fuse) rather than go to the fuse box. I picked up an available ground nearby. I hung the relay underneath the wing using one of the screws binding the body parts. That kept everything close by except for the wiring to the power & ground.
What about this wire? It goes to something that has power with ignition on. I think one of the indicator lights perhaps?
If I recall the diagram there were some wires meant to go into the cab to a switch or something like that (in a different vehicle), but they weren’t necessary with the CA Tuning switch provided.
Looking at the harness it is not a relay. I think it might light the switch?
CA tuned have an installation video here. They link to the wrong video on the product page but I found the installation video for you. Wiring starts at 5:45. They brush over it quickly but I think I can see that stray red wire attached to the jump post, same as the compressor power wire.
The wire in your pic is labelled POSITIVE 15 AMP which I'd be confident is the relay coil wire you're looking for. On a standard relay it would be #86. #85 completes the coil circuit to earth. You might be able to see and trace the numbers on the underside of the relay to the wires in the harness.
Check it out. Temporarily attach all the grounds and connect the switch. Don't worry about the heavy red compressor supply wire. Set the switch ON then touch the red wire ring terminal to the jump post. You should hear and feel the relay click closed. If you get that result you have your answer. Carry on!
I got it working. There is not relay for car running. It is power to switch light. I just connected to the positive side (the fuse). In the video looks like he. Has all 5 wires connected to switch but there is no fifth wire. Energizing that 5th pin on the switch is a second light that is green when off. I did not connect it since no source. Only four wires in my harness for the switch. No problem. Orange light comes on when switch is on.
It all works. Not a lot of places to zip tie or hide wire. Cut a bunch off and tucked it away.
I'm not quite following your explanation, but if you have it working as you need then you're good to go.
There did appear to be a relay in the supplied harness according to the pic on the catuned website but I'm not looking at what you have. What looks like a relay at the bottom might be the back of the rocker switch. Hard to tell.
Glad you got it sorted out.
