The Utility Belt
  • Thread starter Thread starter HT
  • Start date Start date
I found these rails on the doors, except the ones in the back under the windows useless (I also never saw anyone who build such thing on his car and if someone would found that usefull, it had sure been done already).
It might look like "Camel Trophy" but...
... it makes it more likeliy to damage the doors in narrow sitiuations, as the "extension" of the door comes more close to the walls, rocks, trees, etc. That's why rock and treesliders are used, to keep the side of the car away from obstacles. Hanging stuff onto the door while driving is the opposite.
... using it with a net (to put recovery gear in, for example) will just pick up everything you come by and will leed to more scratches and tree branches entangled there...
... using it in a camp...to mount a table for example....at least with my familiy on tour, these doors are opened and closed every 5 miutes. No way to mount somethuing there.
... using it with a solid load, like a can, can lead to something get trapped between can and door and damage, scratshes etc. again....
... dirt trap and humidity trap
Carrying more load on tracks (or maybe streets if legal) could be a point where it might be usefull, water tanks for example (I don't think fuel is not the best idea in case of someone crashing into the side of the car).
And, mountung these rails with minor practically needs special tools to create the door profile, rust protection, additional work für mountung, weight...etc. And the door hinges must proof to be able to handle additional load here.
Hope you didn’t order them on your vehicle 😁 Like you I am especially interested in having the track under the rear side windows. That, so far is where I see them being really useful. I can see the other rails being handy at a drive in cinema. Somewhere for the shake and 🍔? 😁
Park
Take table out of rear and fix it to the door.
Make lunch
Make coffee
Take table off and put it back away.
I didn’t bother with them, I can’t see much use for them, and I figured anything you put on therm would likely obscure the view of your trailer. Maybe a second spare wheel on the rear panel if overlanding… maybe..
I don't like eating inside vehicles and as this will be a work truck I need somewhere to put a laptop (it appears someone has relocated my lap) when I need to do a bit of work between customers.
A quick awning, some detachable tables, fold out chair, fridge in the back and something to make a good espresso
That does sound like the perfect outdoor office. Do you have any experience when it comes to "something to make a good espresso"?
Not in a 4wd outdoor setting
I was hoping someone on here has good recommendations
I don't want to go down the path of an inverter and coffee machine
My wife drinks tea so need something she can use also
Actually one of those little gas canister burners and a billy is probably the fastest most convenient way to boil water on the go. 12v kettles are painful.View attachment 7806262
We use a cheap inverter and a collapsible kettle. But have several other options as well!
Park
Make lunch
Make coffee
My table #1 is in the rear door.
Park.
Open door, table ready, no need to carry anything anywhere.
Table #2 is on the sand boards under the awning, just lower them, done. Even no need to carry an extra table.
Where is the benefit of hanging it somewhere?
Why don't use the rails in the rear if you want to hang a table?
Awnings do not cover front doors.
What I like about the utility belt is that it is a blank canvas for people’s imagination. I don’t 100% know what I will do with mine yet, but looking forward to seeing what creative minds come up with. I like the door table and rear molle panel that Black Sheep have come up with already. Give this group and the aftermarket a year or two and I bet we see some very interesting things
As long as you can boil the water an Aeropress is hard to beat for travelling.
I’ll second that. An Aeropress, Porlex mini grinder and a Keep cup are an essential part of my travel kit these days.
Is this the one?
