Superwinch (Husky) - NOS winch
vtgrenadier
8:26 PM
Vermont, USA
I have a NOS Husky 10 that I've been saving... having owned two or three others over 25 years, I have found them to be the most robust and reliable of winches. Yes... probably overkill for the frequency I now use a winch (as opposed to when I was in my 20s), but I nonetheless have an affinity for it.
I may well order this winch tray, knowing that it has a different mount pattern that would require modification... not even knowing the dimensions to compare against:
Anyone else consider a Husky? Or do I just have to catch up to the times and not complicate things??
anand
8:26 PM
Maryland
Old school Superwinches were great winches from a durability standpoint
As far as fitting... from a quick Googling the Husky 10 has a 10x4.5" bolt pattern, which is the standard bolt pattern for winches, so that isn't a problem for the LFD mount. It does appear to be about 4" wider than a Warn VR, which in the middle of the winch mount should fit no problem (I just went outside and measured, the mount offers ~27.5" of width in the midsection); however it narrows down towards the front slightly, and I'm not sure how that would play with the Husky. Additionally, the "top" surface of the bumper comes towards the rear of the vehicle slightly, again, it may interfere with the shape of the Husky.
I would contact LFD and see if maybe they have (or can acquire) a CAD drawing of the Husky to "put" in the cradle to see if it will fit
vtgrenadier
8:26 PM
Vermont, USA
Thanks for taking the time to do that, @anand
I'm a bit premature in all of this, as my Grenadier is in storage for the winter and inaccessible. This gives me plenty of time to await development of other winch trays and compare the versions of winches offered. I guess I've been operating on the Land Rover Defender experience, wherein the Husky and older Warn patterns differ. If memory serves, the off-set of the Husky made it sort of bumper-specific, if that makes any sense.
anand
8:26 PM
Maryland
Ahhh, that may still be the case then, but the bolt pattern itself is the same. Some bumpers/winch trays have slotted holes to allow lateral movement (not specifically for the Grenadier, but in general); the LFD tray has fore/aft slots to allow adjustment front to back of the winch mounting
