Starlink Mini
grnamin
10:28 AM
Texas, USA
I'm pretty happy with the performance so far. Open sky on the highway, I can get ~100 Mbps. Facetime and audio are actually better over Starlink than strong 5G for some reason.
Very little competition for bandwidth compared to cellular (for now).
300chris
11:28 AM
Colorado, USA
So, looking at options to power the unit. Needs about 60w max, so about 5amps. Could use the existing DTP’s, but has anyone thought about running wiring from one of the the existing INT switches (10amp) up to the roof. Would take a bit of work, but power should be sufficient and you would have a dedicated switch for the starlink, while keeping the rest of the pre-wired (25amp) outlets available for other stuff….
anand
11:28 AM
Maryland
If you're making a longer run on power, definitely consider tossing a 12v->24v (or 36v or 48v) converter in the mix to drop amperage on the small wiring running to the dish
globalgregors
1:28 AM
Sydney NSW, Australia
DVA Mechanics
Supporting Vendor
11:28 AM
Atlanta, GA, USA
AngusMacG
11:28 AM
Massachusetts, USA
Here's the link to the cable if anyone needs one.
Tried to order using Apple Pay. Doesn’t seem to work.
LeonD
11:28 AM
Virginia, USA
I will check on it -- if you PM me your Name, Address, and Email, I will process it for you
There is a picture on X with the starlink mini power cable, it appears to have an in-line fuse. The picture on the web site for the power cable does not have a in-line fuse. Does it require an in-line fuse? Thanks!
DVA Mechanics
Supporting Vendor
11:28 AM
Atlanta, GA, USA
No, but when we were testing the first prototype, we thought it was best to use an inline fuse just in case. We weren't sure what the Starlink Mini's bootup behavior was going to be.
It wasn't required after our testing.
