How different? Can you share your thoughts?I did not order the sparewheel box. - Was considering it - but as of now - there might be an aftermarket solution. Perhaps not made from plastic but aluminium or similar.
The idea is great - but what I demand is a little bit different. - I ve got a fried with 3D Printer .. perhaps design a prototype for something that suits my requirements better.
True, but probably yet another tool every well educated thief carries!
No that was Bushguide's concernAh, I thought you just wanted to move away from the issue of dust in a normal key lock barrel.![]()
The boxes seem mostly plastic - not metal.How different? Can you share your thoughts?
As with everything there is no one solution that suits all markets and all needs.The boxes seem mostly plastic - not metal.
Also it looks like there is no interior shelf or separators. What I dislike if the stuff stored inside is falling around and may be noisy. - Also I like finding and not searching in some bags.
What I also like - is if I had a kind of foldable handle and could after unlocking - the entire box take out and carry it to the place where the equipment inside is needed.
E.g. kind a push to unlock or rotate by a few degrees like a bolt lock, to lock unlock - and then carry the box. - Something like this.
Also the visual presence of a key hole there bugs me - it tells everybody. There is something inside valuable enough that is worth to be locked.
Something like this I had in mind.. Not a simple flap down door molded plastic etc.. .. There I get my problem on value for money. - In all other places Ineos has invested quite a lot of robust capabilities.. but that one just doesn't fit in my opinion.
exactly .. a full cover of spare wheel is something that is a must. Yesterday evening I was out to monitor some grass land that is usually attacked by boar. due to a mixture of rain and snow the area became muddy and wet. The rear of my disco is now rather brown and nicely covered.. so the pressure washer is required.. usual procedure. A covered lock eg by a dirt bag.. is mandatory.As with everything there is no one solution that suits all markets and all needs.
In Australia it's a good spot to store recovery ropes, gloves, soft shackles that don't rattle.
And a dirt bag covers the area so thieves aren't tempted.
Interesting thoughts, thanks for sharing.The boxes seem mostly plastic - not metal.
Do you think that dust will manage to get itself between the door and wheels face? If I’m not mistaken, most soft tire covers sort of end just past the width of the rear tire, leaving the side facing the door essentially uncovered. Typically this is the inside of the wheel so it’s not a big deal. However in the case of the IG that would be the face of the wheel. This would be more an issue with the alloys than steelies.exactly .. a full cover of spare wheel is something that is a must. Yesterday evening I was out to monitor some grass land that is usually attacked by boar. due to a mixture of rain and snow the area became muddy and wet. The rear of my disco is now rather brown and nicely covered.. so the pressure washer is required.. usual procedure. A covered lock eg by a dirt bag.. is mandatory.
