- Local time
- 4:57 PM
- Joined
- Jul 27, 2022
- Messages
- 6,005
But you still have to open the small door first before opening the large door ~ it won't open otherwise?The gas strut is to stop the large door slamming shut and damaging the small door,
Out of curiosity, is the key to the lockable storage wheel cover the vehicle key or is it a seperate key like the lockable cubby inside the vehicle?So some photos are in various other threads but I thought it worth drawing info on the one topic into it's own thread.
My answers are for the UK specification vehicles & just my interpretation of what I have seen and read.
Standard vehicles get no spare wheel cover and so look like this:
Belstaff editions get a hard centre cover and so look like this:
There's an optional accessory for all models, interesting priced the same whether you have a cover or not, of a lockable storage box:
Early prototypes were seen with a more traditional full cover than may have been semi-rigid but this seems to have been dropped, at least for now:
And finally, there have been a few sightings of Melvill & Moon flexible covers on prototypes:
Might be worth adding what the spare wheel carrier looks like behind the spare wheel:
And for those used to cracking rear doors under the weight of the spare wheel (I'm guessing lessons learnt from the Defender) then this is the not insubstantial inner casting to carry all that weight:
I can not imagine that it will be the cars key. It will be a separate one.Out of curiosity, is the key to the lockable storage wheel cover the vehicle key or is it a seperate key like the lockable cubby inside the vehicle?
All doors need to have a good seal all around to keep dust and water out. As there isn't a strut or body section down the middle to close the rear doors on the doors must overlap. The point to the small door is you can just open it if you need quick, small object access. Therefore the large door closes with a seal at the top, bottom and right hand side. Then the small door closes overlapping the large door and seals all the way around. There is no other way to do it and this is the same on all double rear door vehicles.But you still have to open the small door first before opening the large door ~ it won't open otherwise?
Don't they have a sort of twist lock on the jeep I saw the strut at the game fair and it does stop you slamming the door too hard.I'm wondering what force is in the damper to hold the door open on a reasonable slope but not then make it difficult to shut on the level.
I was hoping that there would have been a more mechanical latch to lock the door open.
Yes but after the small door is opened the large door can then open but it doesn't stop you re closing the small door which can then bbbe damaged by the large door shutting on it .But you still have to open the small door first before opening the large door ~ it won't open otherwise?
Yes. Friend of mine has a tennis ball in the back and when he wants to keep the door open he just wedges it in the gap near the hinge. Saves damage to slide out drawers when they are open.Don't they have a sort of twist lock on the jeep I saw the strut at the game fair and it does stop you slamming the door too hard.
100%.Don't they have a sort of twist lock on the jeep I saw the strut at the game fair and it does stop you slamming the door too hard.
My thoughts were to leave the large door open with the table folded down, close the small door. Fold out 270 degree awning and set up table and chairs. behind and on the left side of the vehicle. I am working on design of some shelves to attach to the utility belt on the left side to set up cooking/water boiling and meal prep. Closing the small door just makes it one clear space. Talking about a RHD vehicle in Australia100%.
At the demo drive - I used both rear doors.
1. The large door can only be opened by first opening the small door.
2. The small door is opened similar to the other doors.
3. I can't remember if the small door has a holding latch.
4. You can then open the large rear door with a latch on the inside left side of the large door.
5. With both doors open the large door must be closed first. You could then close the small door over first (but why?) but then not the large door as the large door left inside opening mechanism would hit the right edge of the small door and potentially chip the paintwork.
I want to be able to setup comfortably within 15 minutes of pulling up. Not planning on camping. Just contemplating the world with a drink and a bite to eat.Yes DaveB I can see that set-up working very well with clean access to the fold down camp table
Pretty much the same as a 70 series Landcruiser Wagon or Troopy.100%.
My thoughts be exactly. But I haven't had m much luck on the utility belt table. I even bought a length of track to experiment be with. All my designs are either to fiddly or don't be save space or weight.My thoughts were to leave the large door open with the table folded down, close the small door. Fold out 270 degree awning and set up table and chairs. behind and on the left side of the vehicle. I am working on design of some shelves to attach to the utility belt on the left side to set up cooking/water boiling and meal prep. Closing the small door just makes it one clear space. Talking about a RHD vehicle in Australia
