- Local time
- 3:22 PM
- Joined
- Aug 24, 2022
- Messages
- 2,447
Yep, we were doomed from the startYou know we are the only country to loose a war with a bird....remember the Great Emu War of 1932?............
Can't believe they won and we had machine guns???Yep, we were doomed from the start
Just as well the casowaries didn’t join them, there’d be none of us left.Can't believe they won and we had machine guns???
Actually laughed out loud, nearly spat my coffee at the screenJust as well the casowaries didn’t join them, there’d be none of us left.
Yes. the Ineos ROW metal oneBe nice to see a comparison between the large plastic bumper and the metal one.
Anybody know of better solution to the front bumper than the INEOS version?
Wrong answer!Yes. the Ineos ROW metal one
DaveB, it is perfect! But.......you are in Queensland........Sorry
I just can't see what is wrong with this one???
View attachment 7815214View attachment 7815215
It was posted in another thread that the Bull bar was only crash tested for Australia.Personally think the steel bumper with bull bar looks fantastic! I hope we're going to be able to order them in to the US.
Do you think factory spec'd ones have different front springs or are those bars not heavy enough to warrant an upgrade?
I knew they weren't crash tested here which is why we can't spec from IA, but I'm hoping we can get our hands on them. I've never been a fan of most bars but I think this one hits the sweet spot.It was posted in another thread that the Bull bar was only crash tested for Australia.
You should be fine with stock springs and the bull bar. I was told all the USA test drive vehicles with winches were on standard (no uprated) springs.
The word from Ineos was yes it does change the spring rate when you option the bar and again if you option the winch.Personally think the steel bumper with bull bar looks fantastic! I hope we're going to be able to order them in to the US.
SorryDaveB, it is perfect! But.......you are in Queensland........![]()
Sorry
Apparently Queensland is beautiful one day and perfect the next.
Theoretically then the UK plastic bumpers should have a marginal better fuel consumption that its steel counterparts. But there again nobody drives around with a completely empty vehicle.The word from Ineos was yes it does change the spring rate when you option the bar and again if you option the winch.
It only weighs 40kg but they say you can add another dynamic load of 150kg onto it.
As it is hanging out in front of the springs this would impact the load more and mean a suspension change would be good.
I am guessing the owners on here range from 80kgs to 160kgs in weight, then if you add a similar passenger the weight of the bar becomes irrelevant.Theoretically then the UK plastic bumpers should have a marginal better fuel consumption that its steel counterparts. But there again nobody drives around with a completely empty vehicle.
I have a habit of not letting my vehicles fuel drop much below a third of fuel. That's my 40kg back.
I would live to purchase that roo bar. We have way too many white tailed deer in my area. Always put a non-SRS ARB on my coil-sprung LR's for that exact reason.The word from Ineos was yes it does change the spring rate when you option the bar and again if you option the winch.
Bear in mind that the 40kg stated for the bullbar is on top of the additional weight of the steel bumper versus the plastic.The word from Ineos was yes it does change the spring rate when you option the bar and again if you option the winch.
