Shovel Side Mount Using Utility Belt
Psignore00
1:27 AM
Apollo Beach, FL, USA
This site contains affiliate links for which The Grenadier Forum may be compensated.
Michael H.
4:27 PM
Sydney, Australia
Thanks to all the advice here, I have mounted a shovel onto the utility belt.
I used a pair of https://www.z1motorsports.com/misce...l-quickfist-riser-by-z1-off-road-p-44901.html
Attached to the utility belt using https://www.aliexpress.com/item/1005006954198737.html
I chose the M6 bolts, so I didn't have to drill out the risers.
The shovel I used was a https://www.roofracksgalore.com.au/spade-black-1065mm-handle-blue-grip
Next step is to apply some type of grip tape to the handle (where the QuickFists grab it) to prevent the shovel from rotating and touching the bodywork. 🙂
1:27 AM
Pittsburgh
whats preventing any of these mounting solutions from letting the shovel blade make contact with the truck?
Dual Grenny Guy
12:27 AM
Louisiana, USA
View attachment 7873501View attachment 7873502View attachment 7873503View attachment 7873504View attachment 7873505
parb
10:27 PM
Silicon Valley, CA, USA
I'm a fan. A bit of rubber edge guard on the shovel blade should be enough to protect the paint even if it rotates in it's mount.
1:27 AM
Pittsburgh
Assuming it doesn’t get scrubbed off by the branch or whatever is scraping along the side in the process. Hanging shit off the side isn’t my bag but, if I were to do it the blade end would slide into a firmly mounted pocket.
5:27 AM
For Australian owners be careful mounting stuff like shovels to the side of the car. Watch where the blade of the shovel is directed or where the extra steps or long bolt stand offs for accessory spacing are mounted to the side of the vehicle. Like unused fishing rod holders on the bull bar and some aerial mounting positions there is an opportunity for the police to defect and ticket you for a fixed dangerous protrusion from the vehicle.
1:27 AM
Pittsburgh
If you add rubber onto the shovel blade, it is called pinchweld.
I still don't want it bouncing off the truck sheet mental. If something can flop around, it's not really fastened. I think if one wanted the shovel on the side, one of those panels would be much more solid and safe.
ddv
4:27 PM
Central Victoria, Australia
Looks like a good solution. Have been pondering options and this, together with thedocaus suggestion of pinchweld looks like an attractive option
Dual Grenny Guy
12:27 AM
Louisiana, USA
I’ve been following this thread as was debating changing my roof top shovel mount in these pics to a side mount as I really like the side mount better and it’s easier & faster to access it. First pic was at a weird angle as was checking to see if it would fit into the garage and with some work it actually did!! You may have to zoom in on the second pic to see the shovel on top. When I tried to zoom in and take a closer pic and download to this site I get an error code that image too big. If anyone could help me on that I would appreciate it as I’ve tried adjusting the settings on my phone but no matter what I do when I zoom in on things I can’t download those pics. So if anyone image is not too big when you have the whole vehicle then how can it be too big with only parts of the vehicle? I’m not a tech guy so I’m sure there is a simple solution or reason just above my pay grade as they say. Btw, yes I can access the roof top shovel now using the side “Buzz” step, but I also keep a small stool in the rear cargo area just in case…..😉😎
ColoradoMike
11:27 PM
Colorado, USA
I’ve been following this thread as was debating changing my roof top shovel mount in these pics to a side mount as I really like the side mount better and it’s easier & faster to access it. First pic was at a weird angle as was checking to see if it would fit into the garage and with some work it actually did!! You may have to zoom in on the second pic to see the shovel on top. When I tried to zoom in and take a closer pic and download to this site I get an error code that image too big. If anyone could help me on that I would appreciate it as I’ve tried adjusting the settings on my phone but no matter what I do when I zoom in on things I can’t download those pics. So if anyone image is not too big when you have the whole vehicle then how can it be too big with only parts of the vehicle? I’m not a tech guy so I’m sure there is a simple solution or reason just above my pay grade as they say. Btw, yes I can access the roof top shovel now using the side “Buzz” step, but I also keep a small stool in the rear cargo area just in case…..😉😎View attachment 7873890View attachment 7873891
OUCH! I never want to encounter YOUR Grenadier EVER! :)
BY the way where did you get your Graphics done? They look AMAZING! Cost?
Dual Grenny Guy
12:27 AM
Louisiana, USA
Graphics definitely NOT cheap, but was done with PPF first then the black map wrap on top. Then to finish all off a ceramic coat is being applied this week to finish it off. Couldn’t do it all at once had to let things adhere get dry etc. after that she should be ok to get hit with some small branches and debris off road. I am not doing any rock crawling but will be fly fishing and camping in it. Local tint/wrap/graphic shop I know the owner and been going there for years. I HAVE to customize almost every vehicle I get. Not gonna load up pics on here as have a ton but most of my rides get the custom treatment. Btw, I’m fine with people who leave theirs completely stock. I’m TRYING to do that with my 2nd Grenadier, we shall see how long that lasts……🤷‍♂️🤞
Dual Grenny Guy
12:27 AM
Louisiana, USA
Did you make some sort of map from the passenger to the driver side? I think you had to make that yourself!
I thought I posted both sides, sorry. Yes the map starts on driver’s side and ends on pass side. Basically a larger layout of the same map on the hood. You may have to zoom in on the black map section to see the terrain and details:
Michael H.
4:27 PM
Sydney, Australia
