- Local time
- 12:15 AM
- Joined
- Jul 27, 2022
- Messages
- 6,005
It fits in the Belstaff editions just mounts differently.This explains why the metal mesh cargo barrier is not an available NA option.
Can someone take a photo of the steel mesh barrier installed in a belstaff edition for comparison?It fits in the Belstaff editions just mounts differently.
Nothing waiting to go on a vehicle no, but will have a check to see if one is fitted to a customer car outside @DCPU What exactly is it you want a picture of?We were making progress on that request here:
@Halliwell Jones Chester - don't suppose you have the half height in a Belstaff knocking around?
Given the commercial brackets haven't changed, maybe the Belstaff's remain unaltered also?
Just the brackets/connection points used to connect the half height barrier into the Belstaff.Nothing waiting to go on a vehicle no, but will have a check to see if one is fitted to a customer car outside @DCPU What exactly is it you want a picture of?
Looks to me like the half height cargo barrier for the utility and standard/Belstaff wagons are yhe same but just different mounting hardware. I think on the standard the top goes directly into the holes in the ceiling and does away with the extension bars and at the bottom I think attaches to the tie down hooks on the side, but I could be wrong about that.This explains why the metal mesh cargo barrier is not an available NA option.
Only showing 1 partition panel listed in parts for 5 seat.Just the brackets/connection points used to connect the half height barrier into the Belstaff.
If the seats are moved back in the commercial version and the cargo barrier is to be refitted, then the Belstaff mountings points and brackets seem to be the way to do it. Just looking for clarification as to whether that would be correct and as an additional query whether the mounting brackets would have separate part numbers and be available without having to buy a complete new cargo barrier.
The man is a legend !Try this, it is an upload of several videos.
Ineos Grenadier Owners Club | Anyone who has or is interested in getting the 5 seat commercial but is worried about the rear seat position, I can confirm its a straight forward job... | Facebook
Anyone who has or is interested in getting the 5 seat commercial but is worried about the rear seat position, I can confirm its a straight forward job to put it back to standard fit. Took me under 2...www.facebook.com
And what about the brackets?Only showing 1 partition panel listed in parts for 5 seat.
Just had a quick look through and can't find them sorry. I'm sure they'll be there somewhere though, will have another look when I have a bit more time.And what about the brackets?
Many thanks in anticipationJust had a quick look through and can't find them sorry. I'm sure they'll be there somewhere though, will have another look when I have a bit more time.
Yes see the link in post #28Has anyone else moved the rear seat from N1 to “normal” configuration? If so any additional tips/observations?
Yes, so far nobody has been able to confirm if these carry their own part numbers and are available at reasonable cost.Now, all I need is the fittings to refit the dog guard.
Hopefully, this will soon be resolved. I can't see why there would be a problem in supplying any part that was required. I would also like to know if they will supply full carpets now that they are back on the spec list for the SW.Yes, so far nobody has been able to confirm if these carry their own part numbers and are available at reasonable cost.
I thought someone here had made the comment that the supplied carpet was of a poor quality, and therefore you'd probably be better off going to a local upholsterer to get a better outcome (albeit a template might be needed).I would also like to know if they will supply full carpets now that they are back on the spec list for the SW.
It was back on some PT02s, taken off build sheets, then put back on. So presumably either the material or supplier, or both were changed?I thought someone here had made the comment that the supplied carpet was of a poor quality, and therefore you'd probably be better off going to a local upholsterer to get a better outcome (albeit a template might be needed).
I've a few metres of heavy duty grey carpet which I'll cut to size and get the edges "overlocked" at a business (Northside Overlockers" about 2 kliks from the Bris. Ineos agent in Stafford. If their prices are reasonable, I'll see what I can do to get a template to leave with them for repeat businessI thought someone here had made the comment that the supplied carpet was of a poor quality, and therefore you'd probably be better off going to a local upholsterer to get a better outcome (albeit a template might be needed).
