Famous picCustomer collected car and was passed by his two rear wheels as he braked!
Exactly. With lubricants, friction becomes less. So instead of being destroyed as friction, the energy is simply converted into more tension, so that the screw is overloaded and breaks off.putting any lubricant on the studs or wheel nuts will change the torque settings, allowing you
to potentially over torque without knowing it and if not careful break a threaded stud off
Every screw or bolt is oversized in a machine. The question is how much reserve there is. Sometimes the oversizing is quite high, and you are still within the limit. But sometimes it is not.Most say
don't apply any lubricant, however there are some that say they have been doing so and never experienced any issues.
And very unvented…..those brakes and disks look pretty small....
That's exactly what I've been doing for many years. But be careful, I only use copper paste on steel rims, not on alloys.Theoretically, yes. You should not grease studs as it can lead to over torquing. Bentley motors have a paper on this which you can find online. Personally, based on my 50 years of putting a small amount of copper slip on each stud I have NEVER had any issues and it only made life easier.
Quite right! That's why I don't let tyre dealers on my vehicle. Because they, like many other vehicle workshops, cannot operate a torque spanner.The biggest risk is with people who rely on tyre shops using rattle guns to tighten their wheel nuts.
Check wheel nuts yourself , regularly, if you don't already have this habit.
And beware of actvists and delinquents who are prone to loosening them without your permission.
Yes, on this occasion I've only put Copaslip on parts of the hub face and wheel centre that I can see directly mate with surface contact. Unfortunately, I didn't take photos, as when the Copaslip comes out, anything relatively expensive gets put away.Threads? I prosume DCPU meant the surfaces only?
I’ve not used it in this way. You just apply to leave a thin film?Yes, on this occasion I've only put Copaslip on parts of the hub face and wheel centre that I can see directly mate with surface contact. Unfortunately, I didn't take photos, as when the Copaslip comes out, anything relatively expensive gets put away.
I've always put it on wheel stud threads on Landrovers but this time I'm going to leave untouched and see what happens.
Common for brake pad wear sensors to be only on one wheel front and rear, normally on opposite sides of the vehicle.Might also be worth noting that the brake pad wear sensor only seems to be present for the rear on one side - for RHD this is the offside:
Yes, just a smearing. Too much and it will just spin off under centrifugal force and coat everything you didn't want it to.I’ve not used it in this way. You just apply to leave a thin film?
Spot on.Common for brake pad wear sensors to be only on one wheel front and rear, normally on opposite sides of the vehicle.
If you use something like Molycote 1000 it even helps to get the right torque. This Molycote helps to get an equal and definded friction and thereby torque between different joints.A question, for wheel lugs does greasing the threads do anything negative to reaching a correct tightening torque, i.e. will that lead to overtightening?
One thing I've seen, but not in detail, is that there was a TSB (Technical Service Bulletin) issued for this. Verbally, I was told agents were to paint/spray them.When I picked it up last week my dealer had removed at least the visible portion of it.
An owner should not have to do this type of 'maintenance' on a brand new modern 'outdoor' vehicle. How does a warranty go if you add a lubricant, and later have an issue? I will be asking my Agent how self-maintenance goes and what limitations IA is putting on owners...One thing I've seen, but not in detail, is that there was a TSB (Technical Service Bulletin) issued for this. Verbally, I was told agents were to paint/spray them.
There should be no owner maintenence necessary if agents undertake the remedial work as stated in the TSB...An owner should not have to do this type of 'maintenance' on a brand new modern 'outdoor' vehicle. How does a warranty go if you add a lubricant, and later have an issue? I will be asking my Agent how self-maintenance goes and what limitations IA is putting on owners...
