Front runner now have a full length available and a 3/4 it would seem.
Except it would appear they are telling tales about it being a full length
Task for today - work out where to fix a permanent bottle opener on my Grenadier - got the idea from that J Leno video that someone posted. Roof rack seems a bit high up, perhaps the utility belt....
One for each side and one for the backIf you go with the FrontRunner…
heathen!You can get these nifty twist top beer bottles these days. Quite amazing, this 21st century!
No!? Are you serious?heathen!
you'll be telling me there's screwtop wine next!
That’s a myth! But you can fix this one on your rail:heathen!
seem good valueFor a simple work light these are hard to beat, I have them on one of the tractors. Very consistent wide beam pattern. I had one on the back of my 110 too.
edit, i have the Scene beam pattern.![]()
Wilderness Lighting Compact 2 Lights - Spot Beam Pattern
Wilderness Lighting Compact 2 LED light. Wilderness Lighting Compact 2 Light is available in a flood or spot beam pattern. Wilderness Lighting lights have a 3 year guarantee. Wilderness Lighting Compact 2 10 watts with a massive 1100 lumens of light produced. Wilderness Lighting Compact 2...www.wildernesslighting.co.uk
heathen!
That'll will never catch onheathen!
Yes some of their brighter range are quite pricey but these are good value. They use top quality LED’s so I guess the more chips the lights have the more expensive they become. I have had about 10 different lights off them over the years, they have all worked flawlessly.seem good value
For a work light I’d recommend the scene pattern, for a reverse light I’d recommend flood pattern. For the larger units on the front the combination pattern is excellent, it throws wide and long.I'd like a pair for reversing and working. off the sides as well as the back. worth a punt at this cost.
tks Tom D that is helpful. Will look to investigate a bit more.For a work light I’d recommend the scene pattern, for a reverse light I’d recommend flood pattern. For the larger units on the front the combination pattern is excellent, it throws wide and long.
Only in cheap common folk beer or wineYou can get these nifty twist top beer bottles these days. Quite amazing, this 21st century!
