Reinforces the reason I don't watch or listen to podcasts. 40,000 words when 100 would do.
Sounds like this and other forumsReinforces the reason I don't watch or listen to podcasts. 40,000 words when 100 would do.
That channel and commentators in general talk way too much dribble through exactly what you said.... 10,000s of words.Reinforces the reason I don't watch or listen to podcasts. 40,000 words when 100 would do.
Finally when asked what he would sign write on the side he said "can I keep it" so I assume he is pretty happy with it.
I used to drive out to Broken Hill often in a Ford F150 40 years ago and at certain times of the year you drove into a hot headwind.Fuel mileage in the western US is always going to be bad. Most wheeling is in the west over vast distances. You can travel at 80-85MPH for multiple days! And of course there are hills and mountains. Its just what you have to except. If you have time to slow down, great, but in some places you will get run over. I try in my Power Wagon at times to stay at 72 MPH or so as it helps, but at some point you just have to drive. Seems like turbos are great for torque and elevation, but also EPA testing where they can keep a light, static environment to produce un-realistic EPA numbers easily.![]()
A decent size would be the go and i
Am I right in thinking it’s about $2100 for 2x30L fuel cartridges, mounting plates and pump??![]()
Another Ronny Dahl Video that doesn't contain the Grenadier but shows what a Utility Wagon body on the Quartermaster chassis would compete against in Australia.
View: https://www.youtube.com/watch?v=3KRCsvC4VRk
Exactly.And to summarise - a $50,000 set up spend to get it close to usable, and that’s on a tight budget.
That sounds right, plus another AUD8,000 plus fitting to fix the rear axle width issue.And to summarise - a $50,000 set up spend to get it close to usable, and that’s on a tight budget.
I can remember this question being asked last month, so what you are saying is good newsExactly.
That's why the Grenadier is a realistic offer in Australia.
I have mentioned to Ineos a couple of times that if they brought out a station wagon body on the Quartermaster chassis I think it would sell well in Australia, South Africa and the US
They did say it is designed for that, so after the Quartermaster Cab/chassis maybe.
Hello Sebastien, I think what you are asking for is an extended station wagon on the Quartermaster frame and it has been spoken about in various posts from memory...I believe it would be a great vehicle to add to the quiver but so far I haven't heard of such a Beast...Yet. With the use of the Gren station wagon back extended they could build a seven-seater or just a larger wagonHello,
There is the grenadier station wagon, there is the grenadier quartermaster pickup, a chassis cab, …, is there a grenadier quartermaster station wagon soon ?
Thank you for your answers
I can do most of that and I did not spend AU50,000 fitting it out. Mine is fitted for stills rather than video, but I do some video. But I am not interested in a coffee machine, which alone adds thousands plus more battery capacity, etc.The majority of his $50k budget is for the fit out to work and live in for extended times while travelling for his photography business. Similar money would have to be spent to fit a Grenadier 2 seat wagon for that same purpose. If he is not doing the work there will be a large labour cost involved in the fit out.
I looked at the 70 series and it was more expensive once you fitted it out, compared to the IG.
And If you want a little more peace of mind on long strech of roads, add the Brown Davis long range tank (68L) to The Grenadier and you will reach every corner.Exactly.
