Owl Eibach Lifts
MrWiggles
1:02 PM
Riverside, CA, USA
Hi all,
I am considering the Owl 2.5" spring lift and King Shocks to pair with it. I have heard some concern around lifting the trucks, specifically concerning driveshafts and axels.
Does anyone have any thoughts regarding the Owl lift or lifting these trucks in general? Ultimately I'd like to fit 35s for a little better clearance of jagged rocks on a path I often travel.
Hi all,
Nothing is Owl specific about the lift... It's the same 2.5"F/1.2"R lift that everyone else is selling from Eibach (although, Eibach offers a plethora of spring options and heights now)
Plenty of threads on here regarding driveshaft issues that have been experienced at these lift levels (y)
Hi all,
I was in same boat as you looking into same setup. I decided to hold out and just do wheels to get about 1" more and wait for front shaft solution or portals.
My Grenadier is still parked at the dealership, waiting for the broken front shaft to be replaced. I'm considering restoring the factory springs and waiting for better solutions.
The good news is that you can fit 35s without needing a lift.
What happened? What lift did you have?
The following warning is listed on all Eibach spring kit options for the Grenadier on their main website:
“Damage could occur to factory drive shaft with change in ride height. Consult instruction manual for proper installation.”
Written in sort of vague way to cover both driveshaft failure either being a result excessive wear with prolonged running at increased ride heights or the result of unnoticed damage during installation. Sure, they are just covering their backsides and probably have similar warnings for other vehicle types but anyone contemplating suspension changes should at least be prepared for both the pros and cons which can result from such modifications. Just proceed with caution with your mods and enjoy the vehicle for however you intend to use it.
Hi all,
I did choose to have my lift installed by owl, I feel like any of the shops that are fabricating parts, like Owl and Agile know the truck far better then your local 4x4 Wearhouse does. It has been speculated that improper installation of the lift could be the cause of the Driveshaft failures . So at least if mine fails I'll know it was the lift and not improper installation. Plus it was an excuse to see my uncle in California and drop then Gren off to get the lift installed. I also got their rocksliders and roof rack too.
I got my lift and the King shocks from Owl, and they did the install (in Arizona). I've had no problems = at 13,300 miles now, about 10,000 of those miles were with the lift and 35's - I've only had the Kings for about 3,000 miles. I highly recommend them, they dramatically improved the ride.
What size lift did you go with?
Embarrassingly, I don't even know. My receipt says its Eibach part number E30-34-001-02-22.
Edit: There's a picture of my Grenadier getting it installed on the Owl Vans website, at their 2.5" Pro Lift Kit page - they list it as +2.5" front and +1.2" rear:
Awesome thanks for the info, I am currently working with them to setup a mini build right now and still tossing up idea of 2.5 or 1.7" front all rear are the same at 1.5" it seems.
They are very good to work with and care about what they are doing. I've had great experiences with them.
Owl in Portland did my lift and I am very happy with it. We discussed the potential for front driveshaft issues. They disconnected the front CV and protected CVs from damage during installation. 7000 miles later and CV boots are still in good shape. I do carry TeraFlex replacement CVs and tools just in case.
Would you mind listing the tools you carry to replace CV’s. I would really appreciate it. I already have replacement CV
I'll chime in. Ratchet & T45 to remove/reinstall bolts. a short extension and universal knuckle helps. Hammer, chisel, snap ring pliers to remove old cv . New cv should have grease and instructions. I had no issues removing the original driveshaft bolts, but did removing the dealer installed replacement bolts(I removed the new replacement shaft and reinstalled the old one with the Hi-angle Rzeppa. Now I have a spare driveshaft). Snapped a bolt and had to use a torch to heat all of them to remove. It seems the loctite that came with the replacement bolts is a different strength than that installed on the originals. I also used a ratchet strap to collapse the shaft enough to remove it. Part # for the bolt kit is GRA-5000-019750. Going on memory here, so I may have left something out.
care to give a full review of the king shocks? i've heard that they make rides on washboard much more comfortable yet they work well on highways too.
I may not be the best person to provide this sort of review because I'm used to having an aftermarket suspension and shocks on my Landcruisers for the past ~20 years prior to getting the IG.
But here's my 2 cents: The IG, in my humble opinion, stock has a fairly fast response rate on the shocks. That means that it wallows less in corners (stays flatter), and it transmits the shock of bumps back into the vehicle, more than what I am used to. The King shocks (on the adjustment level I am using) have a much softer ride. On road it has the downside of making you wallow more on harder corners (although since they are adjustable you could change this). But in return you can hit a speed-bump at much higher speed without breaking a tooth. I also feel like the King setup allows the suspension to more easily work freely (on slower trails, it feels like the suspension is drooping and compressing much easier than stock, and perhaps has more travel available, but I haven't measured that).
On washboard roads, from spending years driving thousands of miles on washboard roads in Saudi Arabia, I now do two things: 1) lower the tire pressure to about 15-18 psi, maybe a bit higher in the rear if I have a heavy load. 2) Find the speed at which the frequency of the bumps becomes most comfortable. This varies by track, but there is almost always a speed at which the bumps "smooth out", if you go too slow, wash board becomes much more uncomfortable than at speed.
Around town, at the setting I am using, the Kings are a much softer ride than stock, but again they are adjustable if you don't like that. I do. I have a sports car for when I want a firm responsive experience.
So in short, I like that the Kings appear to give the suspension more freedom to flex, and I like the softer ride around town and on the trail.
Mine goes in next Thursday to Owl in Mesa AZ. I'm going with the 2.5" lift and king shocks. I will report back after I get some miles under the belt, the cool thing is I will be driving just over an Hour to get there and same drive home when I pick it up so I should have a pretty close apples to apples experience.
