OEM Camera Wiring - which wire 12v TRIGGER for reverse?
Itsdchz
10:46 AM
Clovis, CA
Does anyone know the 12v reverse wire that activates camera when reversing? This is the harness in rear 3/4 door: I know red is constant, but which one triggers when shifted in reverse? Thanks!
Thank Flyersfan76.
I just shared his hard work at determining the proper wire when he did an install.
Thank you Flyersfan76!🙂
There is only
White
Yellow
Red
Green
Blue
Red 12v - stays in reverse on Wb
blue - stays in reverse on WB
Black I assume is ground
Yellow video
Green does nothing when in reverse
White does nothing when in reverse
Thoughts
No purple or purple orange
Have a look at this post. #315
Thank you! Makes sense now.
Sorry for the late reply.
You need to connect the red wire on the rear camera to the positive of the reverse light correctly.
To find the positive of the reverse light, you should step on the brake and put to reverse gear, and the other person detects the voltage. The one with voltage is the positive wire.
