NA Trailer Brake Controller Install
Hi,
New to a Grenadier and very new to forums.
I am in Perth, Western Australia.
I have been reading and re-reading this post over and over as I am picking up a Trial Master next week and I am going to attempt the tow pro install myself.
I can see that the violet/orange cable is not working as a 12v on or off to the brake controller.
Is this the same violet/orange core in the photo on page 7 at the trailer brake module loom as pernsdorff's post?
And if it is, can I just cut the cable violet/orange core, heat shrink the end going to the TBM, install a diode in-line and splice it into the blue/orange cable?
Then I can still utilize the cable that was run to under the passenger rear seat.
Or are people just running a new conductor?
As I have not got a car to look at just yet, I am doing a lot of research and planning.
And the second question I have, if there is no cable run to pin 12 in the trailer plug, and the pins are hard to source, I am looking at purchasing a whole new euro plug with all the pins fitted.
Does the grey wire come out somewhere in the loom at the trailer plug on the rear of the car, or do I have to run a conductor out from the cabin?
I was going to change the trailer socket to a large 7 pin round style but have also been reading that the euro style is pretty good too, so will leave it be for the time being.
Thanks,
Ken
Hi @Kenny, welcome to the forum.
This thread is for the US and Canadian markets (NA is North America). Aus spec vehicles have different wiring.
Redarc make a specific installation kit for the Grenadier if you want to go that way. It includes the missing pins for the euro socket. Otherwise the pins are available and it's a fairly conventional installation if you have done a Towpro before.
I picked up power from under the rear seat and tapped into the trailer harness under the right side rear trim panel to connect the brake light trigger and install the diode. I ran a new wire through to the euro socket and installed a new pin in position 12.
There is some info on this in the unofficial owners supplement available from here. An excellent resource. Since you're also in Perth you should hit up @Rok_Dr (Steve) for a signed copy 😉
Probably easiest to wait until your vehicle has been delivered then you will have something to look at.
Hi,
Thanks,
Ken
Not sure if the wiring is different in the US version, or the coloring is the same... and I can't remember what the colors actually were since I did this last year... but baring that disclaimer, I did a continuity test on a friend of mine's Gren and the wire on the brake module end is the same one under the seat. We did exactly as you proposed, instead of running new wire we cut into the (supposed) violet/orange and connected it with the (supposed) blue/orange. The brakes, and the controller, all worked fine after that. If you get the harness off the brake module, it's pretty easy to do the continuity test yourself and confirm.
@Kenny. Welcome to the forum as well.
I can only echo @Clark Kent's, comments and there is a lot more detail in my manual which explains things further. Trailer service brakes have been an issues in OZ but for different reasons to the US market. Some headline bullet points though.
  • Wiring for NAS market cars is different to other markets. They have combined brake/indicator lights, ours are separate. They also and use a 7 pin round blade plug whereas we have the 13pin EU plug which is missing 3 pins.
  • My research indicates that the wiring of ROW (rest of world) MY23 and MY24 vehicles is different. MY24 vehicles have trailer brake wiring provision under the rear seat, in MY23 vehicles this was a 40amp ignition switched outlet as INEOS had originally considered fitting a compressor there.
  • I suspect that the Australian Redarc Grenadier electric brake kit may need to be connected to different wiring points compared to the MY23 vehicles that I and Clark Kent have.
  • Though I may stand corrected the issues in this thread seem to be only present in NAS market vehicles.
  • I would strongly recommend having a chat to Magics Service Manager Alex when you pick up the vehicle and he may be able to advise further regarding wiring connections and provide more accurate information. The forum is a valuable resource but almost all the knowledge here is from personal experiences and reverse engineering as INEOS still haven't released any workshop manuals or even basic maintenance procedures.
  • If all else fails Magic should by now have a recommended auto sparky who can fit it for you.
Steve
I asked the same question and never got a response as I don’t think anyone knows. I think it is likely the same wire running from the control module to the blunt cut under the seat but it may also run somewhere else so most people have just tapped into the blue/orange to get the brake signal and then run a new wire to the controller.
I think what you asked was just cutting the blue/orange and tapping right into the violet orange so you don’t have to run another wire? If so - that’s what I’d do but haven’t confirmed it doesn’t go anywhere else. Yes - you do need the diode in that installation.
Can’t help on the plug question as we only have the 7 pin in the US.
This is correct... I have it written somewhere as far as which pin is each, but technically you can simply jump blue/orange wire that is the brake signal into the tow module to the output wire that runs to the blunt cut under the back seat, and the brake controller would work.
Thank you! Seems like a much better solution, jumping the wires, vs running a dedicated wire back to the TBC. Any idea if the wire also does anything else?
From what I have been told one is brake input into the TRM, the other is brake output from the TRM to the brake controller wiring under the back seat, that's it.
I got tired of waiting for a fix from Ineos and went ahead and ran the wire to the brake light wire in the back right, together with the Redarc EPDK-001.
Getting those body panels off, was a major pain in the ass. For others who haven't done this yet, the order of removing the plastic trim panels is first the big panel over the wheel (first remove the cargo tie down screws, then the three screws behind the three black circles), then the top back panel (next to the side window), then the bottom right panel.
I couldn't figure out how to remove this clip (circled in red in the photo below) to get easy access to the orange and blue wire, so I ended up removing some of the tape from yellow circled part and tapped into the line there. Thanks for everyone that contributed to this thread, its a great resource that I needed to refer to about 100 times.
For the wire connections, in the back (by the photo) I just used a t-tap. Under the seat I used Wago 221-2401 inline lever connectors that I wrapped in electrical tape. Its the first time I've used those and now I'm sold, so much easier than the other methods. Last time I used heat-shrink connectors, but the wires in the IG seem to be very susceptible to heat because the plastic coating became very soft and stretchy at the temps needed to shrink the splices.
My general thought about all of this is I'm pissed. I'm not very good at this kind of shit and I resent that I had to do it when I paid extra for the towing package. It is complete BS to advertise that the IG comes with a towing package capable of 7716 lbs, when there is no sensible way to connect a trailer bake controller. Particularly since in most US states it is illegal to tow anything over 3000 lbs without trailer brakes!! (including in Washington where I originally bought my IG and AZ where it is now)
All in, between installing the original Redarc controller and this additional wire trigger, I'm probably at about 8 hours of my time. Worse than that, I've done about 6,000kms thinking I had trailer brakes when in reality I only had the inertia brakes. Ineos needs to get off their asses and fix this before someone is inevitably hurt by this!
Sorry for the rant... maybe I should have waited a bit longer after installing before posting.
Can you share what wiring was like on the EPDK- the instructions indicate hooking to tow bar side and trailer side. Wanted to verify.
Hi - I don't remember exactly, but I do remember that I followed the instructions that came with the EPDK. Is there part of those instructions that's not making sense to you right now? If so, show that here and maybe it will jog my memory?
Thanks for the offer to help!
I understand the connection directly to REDARC
I assume Pin 6 on trailer wiring is the purple orange we tap from TRM as an input to the diode
What is the Towbar, middle connection- this goes to the dead wire on IG harness? Not needed though since it is dead?
What is the Towbar, middle connection- this goes to the dead wire on IG harness? Not needed though since it is dead?View attachment 7891561
I just looked at mine again and maybe I did mine wrong, but I have the left red wire connected to the brake controller, the orange wire tapped into the purple/orange from back by the right rear brake light, and the right red wire I just have taped off (not used). Everything seems to be working correctly.
I believe you are correct because the TRM is acting as the 7 pin controller, therefore not needed.
Just making sure, you totally clarified for me.
Thank you 🙏🙏
I just purchased my Grenadier. Ended up getting one that needed me to add some stuff so the tow harness is one, Man that is expensive! Price doubles if you have winch pre wiring because of the high amps to the rear. I decided that my must haves were the locking diffs, Safari windows, and the aux electrics everything else can be added. This opened up my choices a bit as the loaded one there was only a Demo and I found lots of scratches and some nicks in the leather seats from folding flat and hitting the frame. (Will have to pad that).
When they are putting it on after reading all of this I am wondering if there is anything I should tell the service guys to look at or test? They don’t do non OEM stuff but should they test those four wires for a positive brake signal or is the final verdict here that we combine those two wires or splice into the module? I am thinking that they can’t really help me on this. I will have to review these posts.
I am going to add a hidden winch from GP factor and I could install it myself but Owlvans has an installer near me which is pretty cool. Maybe they can do this redarc thing. I installed one on my Defender but Redarc had a wiring harness that just plugged in to the car.
I will order the parts and study this thread. I just skimmed it initially. Hopefully I can learn from all of your experience.
Somewhere I saw someone who had a rectangular mounting plate and this dial would be one of four devices on it. Looked very clean. Have to decide where to put the dial. Wish I could find that post or YouTube video.
