- Local time
- 1:55 AM
- Joined
- May 19, 2022
- Messages
- 2,228
That's right! That's a good idea - why should the neighbours be allowed to sleep longer?We specifically use the front doors for in/out when camping around others![]()
Our seems to be fixing itself. If you put it on front and feet it’s super hot. Goes down to warm when you put it on front only. Rear vents are warm. We’ll get it looked at in two weeks when we get our accessories installed.Same, turn the heat up all the way and it just gets warm and barely warm. I did find that if I turned on the auto switch it would get hot but it blasts the air at the top setting with no way to turn it down without it totally shutting off.
Congratulations to you. A great vehicle. Enjoy it.Picked up mine yesterday at Triad Ineos in Highpoint NC. The dealer was great. Jason the GM is on the ball. Drove her 175 miles home to the coast and the vehicle exceeded my expectations. It is a beast in person. Pics don't do it justice.
Mine did have the loose/non adhering gasket issue on 3 of 4 doors and rear door. Dealer was made aware to order replacement gasket seals. Of note in pics is a gasket quick fix they did to all the doors. Dealer did not know about, so must have been done at port upon arrival. You can see the round, punch like holes to the bottom of gasket. 2 on each door.
Other than that no issues.
Congratulations Tarheel, That is a great color combination. Instant Classic. Happy New Year! DaBullPicked up mine yesterday at Triad Ineos in Highpoint NC. The dealer was great. Jason the GM is on the ball. Drove her 175 miles home to the coast and the vehicle exceeded my expectations. It is a beast in person. Pics don't do it justice.
You are completely right, this is a quick fix for one problem, and will create another problem: what about water tightness while wading in 80 cm water?I told my dealer to just keep his hands off my seal. I don't want to have these cut-outs afterwards.
Colour appropriatePicked up mine yesterday at Triad Ineos in Highpoint NC. The dealer was great. Jason the GM is on the ball. Drove her 175 miles home to the coast and the vehicle exceeded my expectations. It is a beast in person. Pics don't do it justice.
Degree of inaccessabilty may be more in the eye of the beholder ... RHD vs LHD. At least we are not dealing with incomplete wiper function on driver's side and an air intake tower blocking some field of view as our RHD colleagues are.Have you seen where the Oil filter is, driver side back of engine! Could it be more inaccessible? Freaking engineers. At least the oil pan drain plug is easy to access.
They should be the halo rings only on around the headlights for DRLs.Is that an issue? I prefer my headlights on at all times the vehicle is running.
The hole punch is bad. It would have been much simpler to slice (make a slit) like 1990’s LR D1 door seals.Congratulations to you. A great vehicle. Enjoy it.
These cut-outs are now made on all Grenadiers in production. This is the solution to the water problem. For me, that's bungling. I told my dealer to just keep his hands off my seal. I don't want to have these cut-outs afterwards.
Yes and the DRLs can be disabled in the Settings Menu.They should be the halo rings only on around the headlights for DRLs.
Agreed! thankfully it settles down but it comes up to heat very quickly.One interesting quirk, not sure it's an issue. The seat heaters, my wife and I used driving home through Utah at night in the freezing cold (20's F) and when we first turn on the seat heater - to lowest, or 1 light, it gets pretty hot fairly quickly, but then mellows out and cools down to the perfect temperature, as far as my ass is concerned.
