New Forum Member from AZ, Not an Owner. (Still researching)
6:59 PM
Arizona
Hello everyone,
I’m new to the forum and currently in the research stage for an Ineos Grenadier. I don’t own one yet, but I’m giving it serious consideration. My interest was sparked about a month ago when I saw a Grenadier wagon on static display at Westfield UTC in San Diego. While checking it out, I had a great conversation with an owner, which pushed me to start looking into the vehicle more seriously.
I’m not new to off-roading. I’ve owned a 1994 Hummer wagon since 1996. The Hummer has been a great off-road truck. However, its on-road refinements are less than desirable. Since I live about three hours from the nearest Ineos dealer, either in San Diego or Phoenix, I’m trying to gather as much information as possible before making the trip.
I'm looking forward to learning from the community here and hopefully making the transition from researcher to owner soon!
Cheers,
Rick in Yuma
Hello everyone,
Cheers,
Rick in Yuma
Hi Rick. Welcome here. There is a lot of excellent information here. If you read along for a while, you will quickly realize which posts will help you make a decision. Keep trying to make contact with owners though, you might meet a few more in your area. And don't let posts put you off. It is an excellent vehicle. Even if there are things that could have been done better, such as the heating and air conditioning system.
Thank you, Rovie.
So far, I’ve found the information here to be incredibly helpful. I’ve been active in other forums before and have learned to distinguish between the disenfranchised owners and the true enthusiasts. I’m already on episode three of Stu and Krabby’s podcast, and between that and this forum, I think I’ll have all the data I need to make an informed decision.
Living in the middle of the Sonoran Desert and with Yuma being the sunniest city in the U.S., your comment about air conditioning definitely caught my attention. Early Hummer models had similar issues, particularly with the wagon variant, where the A/C struggled to cool the entire cabin. Some owners, myself included, installed a custom-made, clear plastic curtain between the back seats and the cargo area to help retain cool air. Later, a secondary A/C condenser and fan were mounted in the cargo area, similar to a residential mini-split system. I have no doubt that, over time, Ineos will refine and improve the Grenadier’s climate control system.
I’ll be in the Phoenix area on 4 February. I’ll be near the Scottsdale dealership and hope to be able to stop in and take a closer look.
Rick.
Thank you, Rovie.
Rick.
Just to put it into perspective. My air conditioning cools the interior well when the outside temperature is high and the heating warms the interior well when it's cold. However, you can't regulate the temperature evenly in fine increments. There are always jumps from time to time. After switching off the ignition and restarting, however, the temperature can be completely different again. I can cope with this and can live with it. But it's not a G Wagon that works perfectly. At least that's my experience.
Reactions: CRH
If you are interested in my technical stuff here are some suggestions (it does have an Australian emphasis):
  1. Download and use the Rok Dr Guide here.
  2. Grenadier Accessories (huge selection) available here;
  3. Kanvas bags and products here;
  4. Information concerning Deutsch DTP plugs here;
  5. Learn more about the CTEK SMARTPASS 120S and 250SE here;
  6. Littelfuse FHZ busbars used in the Grenadier here;
  7. Various recommended torque settings here;
  8. L track information here;
  9. Suggested Grenadier or QM fuses spares kit here;
  10. What do you use on bolts/screws to stop corrosion, galling and seizing here;
  11. Guide to terminal crimping here;
  12. Anderson plug pitfalls here;
  13. Outback driving tips here;
  14. Cheap battery monitors here.
I’ll second this - the AC works alright - but it’s kind of loud and not calibrated to small incremental adjustments. There were some problems early on where the hoses weren’t tightened correctly so those units had to be tightened and recharged - but nothing wrong with the system, itself.
a) wait until the HVAC has completed its start cycle before starting the car (a few seconds). Interrupt its start up with the ignition and you are prone to getting heating when you want cooling.
b) make sure the fluids are level (air bubbles can work their way through with new cars and fluids.
c) manual cooling/heating setting makes it cooler or hotter than the auto setting. (at least for me it does)
Other things of note:
a) its not an SUV. Its a UV. Don't expect it to be an SUV.
b) some people hate the steering. I have no issue with it The turning circle is not a problem for me. Nor do I drive it like I was in a 1950s movie. It drives straight and true if you dial the body sway out of your brain and reactions - some can. Some cannot. If you are relaxed on the wheel, it is fine. If you are a firm gripper of the wheel then its going to be white knuckles for you.
c) It is fantastic in the rough. It feels like a Discovery 2 on the road with a Discovery 4 interior. The rougher the road, the more comfortable it gets and the better it is to drive.
d) its not perfect but no car is. But it is damned fine at what its primary purpose is.
A couple of weeks ago, I drove 600 miles in a day and had just one stop for 20 minutes. It was -6c temp and freezing fog for much of it. Got out at the end of the day and didn't feel any discomfort.
Rick, I drove mine across Colorado, Mojave, and Sonoran deserts in summer heat and haven't had any issues with A/C.
Just don't expect the output to be proportional to your input :)
