Low Range Shift Cable Support Bracket
JKAlpine
12:23 PM
Alpine, TX USA
I added the Low Range Shift Cable Support Bracket from Agile Offroad yesterday. I originally ordered after seeing how the factory zip-tied the cable to a wiring bundle. The zip tie is very thin and stiff, so my biggest concern over time was it cutting into the wire harness (I've seen zip ties cut into engine mounts on an airplane, believe it or not!). I always use GripLock Zipties (https://griplockties.com) to eliminate chafing and cutting, and I usually use a stand-off. The bracket is solid, and it's a tight fit. My only concern now is the cable rubbing the heatshield, but I would rather that than a wire harness.
Has anyone had any issues after installing the bracket?
