Looks like we have choices in US for Diff Skid Plates
Custom Offroad in Australia are doing stainless steel bash plates for the Grenadier. They no longer do Aluminium, instead 3mm or 4mm stainless and the weight is less than the Rival plates you guys have been mentioning. Great quality and great price AU$459 including freight to metro areas gets 4mm SS transmission and transfer case plates weighing only 21kg all up.
Mine just turned up today.
From their web site:View attachment 7862088
Off to talk to them on Thursday about whether they can make a few more bits especially to protect trailing arm joints and the diffs
Yeah get the to crack on will ya :) I already have their bash plates
Finally got the rear diff plate on. Same happened as with @PNW_IG: Forward holes aligned and only one rearward hole. Last plate hole wouldn't align with threaded chassis hole so I used a step drill to widen both rear plate holes. Was able to seat the last bolt with the extra plate wiggle room. I'm good for only one plate per day. Too hot outside even at night.
I received the "re-engineered" Agile Off Road rear skid and it fit perfectly. 5 Minute install, very happy. They called it re-engineered, looked the same except holes lined up.
Has anyone else went with the SPP plates? I bought their total kit with 8 pieces and they even powder coated them red to match my frame. The kit is well made, sturdy and heavy as hell. I honestly can’t recall the price on the powder coating, but you can email Mr. Lars Becker via the link below and he will hook you up and take care of you. I am in the USA and this does come from Germany so there is some shipping costs, but again some of the pieces weigh a ton. See pics for thickness as I believe this may be the thickest set out so far at 6mm (high grade aluminum they say). I did some “light” taping and standing on etc and I have no doubt it will absorb some punishment. I’m not ever going rock crawling, but will be off road in some rough spots eventually so getting it ready!
So, as of March 2025 what are the best options for aftermarket skid plates for the gas tank, diffs, transfer case, etc?
1) Would you recommend any particular brand for utility, durability, and ease of installation.
2) Will they require removal for any normal maintenance like oil, diff, or transfer fluid changes?
3) What are the downsides to look out for. I drive a lot in snow and mud. Are some better or worse for packing mud and snow in places I don’t want mud and snow?
2 & 3 are something that I have wondered about. Interesting to hear everyone's opinions?
I've been digging through the options and have found 5, sort of 6,. All are aluminum and all 3/16-1/4" or 4-6mm.
  1. Rival
  2. SSP
    • https://www.spp-overland.com/product-category/ineos-grenadier/unterfahrschutz
    • Advantage: smoother mating between panels and recessed or level hardware for a smoother sliding surface
    • Disadvantage: significantly more expensive than other options
    • Available in with different finish options
    • The panels are larger and cover more area than others, but may be extraneous
    • Front and rear plates in the works
  3. Agile Offroad
  4. Almont 4x4
  5. Offroad-Tec
  6. Black Sheep Innovations
I'm still deciding on what I will go with, but I'm leaning Agile Offroad. I did order the Black Sheep Innovations rear skid plate and would have ordered the front, but I'm likely going to replace the front bumper anyway so I'm waiting to see what Dissent Offroad puts into production.
  1. Rival
  2. SSP
  3. Agile Offroad
  4. Almont 4x4
  5. Offroad-Tec
What were the advantages of Agile’s armor?
Price is good, they come in different finish options so I don't have to get them powder coated myself, and other than the mounting hardware they're pretty pretty smooth. I'm a bit concerned that they don't appear to have an access cutout to service the engine oil. Otherwise I'd say the Rival ones, I just don't like all the potential hangup points around the forward crossmember.
