It’s not so much the width and height of the tire, if it forced me to get a lift that wouldn’t be the end of the world, but it might be the end of me parking in my 7 foot gara
I know, but my wife would love it if it didn’t fit. Then she’d get to park in the garage.
With a KO twos 285/70 R 17s, what pressure are you guys running? I was up in the mountains on the highway going to high 80s miles per hour and I got an over pressure warning at 47 pounds. I think it’s just the way the TPS is set. also, what temperature are you guys seeing on your tires? Mine were between 100° and one of them the rear driver was 115. I don’t think that’s overall too hot but considering it was 55° out but I was interesting. Thought that the difference across them was interesting. E Rated tires.
Ouch, that's cold..oh wait my Ineos and daughters Mini countryman in the garage...wife's Subaru sits out in the driveway. 2 strikes against me...1)making her drive a Subaru 2) having her car sit outside all winter.
It’s not so much the width and height of the tire, if it forced me to get a lift that wouldn’t be the end of the world, but it might be the end of me parking in my 7 foot garage.
So a buddy of mine brought his grenadier to my office and house today. Both 7’.
If you have a 2.5 lift/ 35’s on 17” wheels you will fit by the hair of you chinny chin chin.
Office garage that say 7’ had plenty of room with rack!!!!
Hello ladies,
Anyone know what the largest tire size is that can be used without rubbing, binding, and without cutting the vehicle to make it fit?
I'm also wondering if there are any options out there for upper control arm replacement to properly lift the truck say... 4 inches, while retaining correct angles.
Lastly... I see that spare tire upgrade size will likely be limited by the left rear access door needing room to open before the right side... looks like about 2 inches further would be the max...?
Hello Lovely
I recently fitted a set of BFG 285/70R17 Mud Terrain KM3 on factory aluminium wheels. The 285’s are the suggested largest upsize for KM3’s without replacing the rims. Results include: Overall diameter increase, 30 mm bigger than 265/70R17 muddies resulting in greater ground clearance of around 20 mm (3/4 inch) over the A/Ts. Speedo is now more accurate moving from 5% under to 1.5% under. They feel so much better, more positive feel and greater directional control on all road surfaces. Mmmm! Muddies!!! Cheers Pete
Factory, aluminum 17? In the US we only get 18 inch aluminum rims…
There's also the above shown 17" aluminum wheel as an option on all Trialmasters and Base SW's here in the US
So far so good. No louder than the stock ko2's and seems to handle a bit better on road.
I ran these in a different size on my previous vehicle and was very happy with their offroad performance and wet tarmac was light years ahead of the ko2's on the Grenadier
Still happy?
How abt the noise on the road?
Gas ⛽️ drinking difference?
Thank you!
If you have pics to share ;)
I just put Yokohama X-AT's on in 285/75/R17 on the stock steelies and still clear the rear door by a few mm.
Yes- with Yokohama G003 in 285/75 17 there is exactly 1mm of space …..😂👍💪
  • 4bee38f9-ace7-4898-a9d1-a57fb6990d37.mp4
    2 MB
