Just tinted them Yellow.Great option too! Are your lights tinted yellow or are they aftermarket lights?
And maybe 265/75/17 doesn’t exist no…?Hi there!
Can you share good pictures of your Grenadier with those sizes?
265/75/17
275/70/17
I’m hesitating.
Wanna keep the original 17 ineos wheel which suit me.
Just want to improve the look without going up with gas️, also, dont want to modify the rear door.
Would be very happy if you can share pics and experience.
Merci! Thank you!
If you go to page 24 it looks like the largest on OEM wheels will be the MT 255/85 17s.And maybe 265/75/17 doesn’t exist no…?![]()
Impossible to increase diameter and/or width without impacting efficiency at least a little.Just want to improve the look without going up with gas![]()
Nah that’ll fit. Afaik any real diameter under 34” shouldn’t need a spare relocation bracketHi.
Do you guys know if by choosing 285/70R17 I need to buy an accessory to put the spare wheel on the right or it will fit like that?
Tha k you!
This looks great. I am also a fan of the OEM+ Concept. Took me a minute to tint my windows.. did it out of necessity due to cargo area not having a cover. How much of a hit did you gas mileage take?Thanks for the input… I did run across this setup looking around online 275/70 on the stock 18” alloys. I think it’s a really nice balance of a little extra muscle, ground clearance while maintaining an overall stock look. I just wish they made this size of the KO3s in blackwall as I’m not a big fan of reversing the tires to hide the white lettering. I like the OEM+ concept without going over the top but everyone’s styles are different and that’s okay.
Tyres in same sizes can vary but fyi 287/70/r17 BFG KM3 fits on the original spare mount no problemsHi.
Tha k you!
Thanks!Nah that’ll fit. Afaik any real diameter under 34” shouldn’t need a spare relocation bracket
I think the general consensus is 285/70r17 fit without a lift but 285/75r17 needs a lift to not rub.Lot of back and forth so will ask
Is anyone here running 285/75r17 on STOCK steel with no mods of any kind? Seems like people keep posting a photo and then say they have a lift. Looking for no mods.
I get the consensus but I want to hear from someone that's hand's on tried it.I think the general consensus is 285/70r17 fit without a lift but 285/75r17 needs a lift to not rub.
I've got 285/70r17 on with no rubbing have been off road multiple times with no issues. Rear door opens fineI get the consensus but I want to hear from someone that's hand's on tried it.
Interested to hear on that as well, particularly on BFG KM3's. (running 285/70/17 on stock steelies at present) As this would be my next purchase of choice once present KM3's wear out.Lot of back and forth so will ask
I know it's early but how do you like them?I just put Yokohama X-AT's on in 285/75/R17 on the stock steelies and still clear the rear door by a few mm.
My Blacksheep bracket broke off the bottom tab and my 35” tire ended up banging into the back door. Ended up with dents/paint scrapes. The design seems to be faulty. :-(Interested to hear on that as well, particularly on BFG KM3's. (running 285/70/17 on stock steelies at present) As this would be my next purchase of choice once present KM3's wear out.
I think the extra 0.56"/14.25mm could well impede the boot rear 1/4 door opening as at present pretty close. Though guess a Blacksheep or other bracket is an easy enough fix if necessary.
