- Local time
- 10:31 AM
- Joined
- May 15, 2022
- Messages
- 1,474
- Reaction score
- 3,795
- Location
- Sydney NSW, Australia
Looks great! What do they do to the speedo accuracy @Caveman ?Fitted today 33” 295/70R17 KM3
Any rubbing on full lock? Assume you dont know yet about full lock and full articulation?The rear door has heaps of clearance.
Great to hear on both accounts, though I am a bit surprised.@globalgregors the speedo is spot on accurate at 100kph.
@James No rubbing plenty of clearance. I dont have a flex ramp to test on full articulation but i have no concern at this point.
285/70 works, so 285/65 should definitely work as it is shorter in height. With that being said, for a winter tyre, you generally want to go narrower vs. wider (unless you are using it for flotation purposes in powder situations, but then you need much wider)Looking at winter tyres, do we think a 285/65R17 will fit ok on the stock17” steels?
Very similar rolling radius according to my sums but obviously 20mm wider
NOTE CORRECTION!: I'm thinking a "pizza cutter 33" (255/80/17) might be good! You actually get a better contact patch aired down with these tires! Available in Falken Wildpeak!285/70 works, so 285/65 should definitely work as it is shorter in height. With that being said, for a winter tyre, you generally want to go narrower vs. wider (unless you are using it for flotation purposes in powder situations, but then you need much wider)
Not sure what is available in the UK... But here are a few options to look into for dedicated winter tyres:Yeah, hard finding winter tyres in any size suitable for the grenadier with 17” wheels, 18 no problem.
And don't forget to leave articulation room for chains!285/70 works, so 285/65 should definitely work as it is shorter in height. With that being said, for a winter tyre, you generally want to go narrower vs. wider (unless you are using it for flotation purposes in powder situations, but then you need much wider)
285/65/17's https://www.mytyres.co.uk/rshop/tyre/Bridgestone/Blizzak-DM-V3/285-65-R17-116R/D-123901. I'd need to search a bit more on the LT side of things but it's a startThanks very much , ive not been able to find any of those here
I am considering same tire size. What is your experience with those tire sizes in terms of turning, full articulation, fuel consumption and gearing?Here are 33" Duratracs (285/70/R17) vs standard KO2s (265/70/R17)
View attachment 7807632View attachment 7807633
Now that you’ve had these KM3’s a month, have you had any scrubbing issues?Fitted today 33” 295/70R17 KM3
No Issues. Ill be taking it on the sand dunes over NYENow that you’ve had these KM3’s a month, have you had any scrubbing issues?
I’m planning to put the same on my truck.
Thanks!
Sounds good! Have funNo Issues. Ill be taking it on the sand dunes over NYE
Here are a few options in 255/80 R17 (33 x 10 inches)Is there a distinction between tallest and largest? Is there a pizza cutter faction? I'd love a tall skinny 33
@anand loves the pizza cutters!Is there a distinction between tallest and largest? Is there a pizza cutter faction? I'd love a tall skinny 33
