It is happening, Long Range America is building Fuel tanks for both Grenadiers
I do look toward to install reports. But showing my cards, for that price I’m a Jerry can man.
If you don't tow, and rarely go where you need 200+ miles of range without access to a fuel station, then yeah its a hefty price to pay. I suspect that once you buy the tank, pay for installation, and pay to modify the exhaust, it will be in the ~$4K range (at least).
I wonder why IG didn't offer this as a factory option.
I would imagine partially the (fairly) low uptake rate of the option and perhaps more so the additional testing/verification/certification processes required for an OEM to offer something like this.
As far as final cost installed, hopefully at the end of April I can make a post about that :) But depending on what the labor rate at your local shop is, I would imagine you aren't too terribly far off. I would imagine 8-10 hours for the install which is similar to their other add-on tanks (in comparison to <3hrs for their replacement tanks)
Probably highly market dependent, I'd imagine the uptake in Australia would be pretty high..
I'd say AU would be relatively high versus the EU or NA markets but still low volume.
Only a small number of AU owners will actually use their Grenadier for extended travel in the remote central and western regions where fuel range is critical for survival. Ronny Dahl commented in a recent trip along the Gunbarrel Highway that he was closer to space than the nearest town. Cute but real.
Much of the outback is being opened up by agriculture (export cattle) and tourism which brings sealed roads, fuel stations and McDonalds. Probably not in that order.
I'm happy for the aftermarket to develop low volume accessories like aux tanks so they're user-paid and not funded by a factory program where we all pay whether you tick that option or not.
Gunbarrel Highway (it's not a highway).
Image: Hema Maps.
Unfortunately, there are almost no aftermarket fuel tanks that are legal in California because of CARB. LRA will not ship any of their tanks to any California address.
That said, there are lots of overland type vehicles in California with LRA tanks without issue. LRA will ship the tanks to any other state such as Nevada or Arizona and an owner could get one and bring it back to California. Once in California, the only time the fuel tank issue might come up is during a smog check, but smog check stations are not generally inspecting for fuel tanks. They only check the engine compartment and make sure there is a factory fuel filler with working gas cap. If someone painted their auxiliary tank and removed any obvious LRA logos, they would pass smog checks with no problem.
Smog stations also check that the vehicle computer (as it relates to emissions... aka tune) has not been modified.
Its a gamble depending on the tech. I had a friend that bought an out of state vehicle with dual tanks. When he went to SMOG it, the tech noticed that it had dual fuel fillers because of the Y design of the filler neck and failed him on the spot. It's these situations its good to have a friend that works at a SMOG shop.
Does anyone (Long Range America) have a comparison of the audio difference? Between Nevada and Utah, I would really like the extended range without a lot of fuel mounted on the side. As a daily driver, I would like the hear the difference in the exhaust. Louder is not better for me.
I am in the same place. I would already have ordered a tank from Long Range if I knew what the modified exhaust sounds like.
I called and left a message asking if I could purchase just the pipes and didn’t get a return call. I’ll try again some other time.
I like some others are on the short list to get theirs ASAP, I will make sure to try to get a quality sound bite for you all to choose. But my understanding is it will be near end of March or so from the last update I got.
If you are willing to do that, you could just go to a exhaust shop and have them build it out for you. Last exhaust I did here in AZ custom ran on a square body chevy was 390 all in.
Considering the cost of kit I didn’t think it’d be too much more than 500 and it’s already sorted. On an hourly rate view of my time, why deal with bullshit when for a few bucks more is hassle free.
Yeah I see your point, didn't factor in if you would just cut the current system and pull it down and if you didn't like it weld it back together. From what I gather its all one solid exhaust.
also found this it should basically be the same thing since both are muffler deletes.
View: https://www.youtube.com/watch?v=CYdUSLFvFJU
I doubt it will be as loud as that one since that is a muffler delete, the version on long ranger's website says, "Requires new muffler, which is included in the kit as pictured."
https%3A%2F%2Fc86895a35860a1abe36ee1122c996085.cdn.bubble.io%2Ff1734716305278x358380747193227900%2FPC050741%25202.JPG
Yeah it does look like it will be just as quiet as the OEM then. Maybe barely above it.....
I didn't catch the expanded tube would be a muffler. Not much, but may be all it needs. Good point.
