Inverter retrofit . New deliveries I need your help .
the guys who are getting the Inverter i think are the ones after the second price change . up to nymber 6k no inverter yet . you might be right i might have to wait for the americans :)
Keep in mind they will be different as the US is the only first world country using 110V AC 60 HZ
Yes i am aware of the differences . but that is on the inverter side , what i am looking for is confirmation of the install in the car . From fusebox onwards .
what the inverter will output is a problem for later . Only one part number existed in the catalogue so i assume it is either a switchable inverter or hopefuly the correct one . :) time will tell .
INteresting diagmram though .
Question is, will it be a production line install or a local country install?
Once you start playing with AC power there are a lot of country specific wiring standards to take into account,
from fusebox to inverter will be normal car DC fused wiring.
From inverter to scoket mpt sure yet . The sockets ( which got delivered a month ago ) are essentially like univeral PDU ( Power distribution unit ) socket , incorporatiing botrh eu+ uk plugs .
It is time they just admitted that they are a northern state of USA
I was meeting a client for first time and I made a joke about Canada being the 51st state when it comes to Canadian Government Bonds. I got zero laughs. I'm like how could you not laugh at that joke, every person laughs. They replied I'm Canadian. I responded, "have a great day A" and left.
You would get a similar, or probably less polite reaction from a Kiwi if you suggested that New Zealand was the 8th State of Australia
Or that Tasmania was part of Australia 😁
Bloody mainlanders...
If you check our constitution it is a state of Australia
Not quite, but the constitution leaves the door open to the possibility.
Yes the new Delta 2 looks good no wiring and you can take it anywhere.
plus you can take it out of the car and charge it on any household socket in very short time. I am very happy with my delta 2 and can highly recommend it. It is a plug and play solution that solves all my electrical requirements when out on a trip. Including solar charging. There is no additional inverter needed since the built in one is very capable. The only downside i could find is that it's charging current is limited to 8 amp on 12V. But you can come by this with a little trick...
What little trick ?
