As long as the fuse, cables and ventilation (and fire extinguishers) are up to it , there is nothing to worry about. Except flattening your battery by mistake! And 240 volts in the rain
There's enough power theoretically for a small induction cooker (when you've been banished from the kitchen or off on your quiet time solo adventuring ?)I don't know, only for the fun of having it, perhaps charging my computer when travelling?![]()
You got the bigger trim panel???i am 99% sure it is like this :
inverter gets power from the little fuse , fuse box . if it is a 2000w would likely need a 240amp fuse ( will be confrimed once i get it here) . there is already an empty slot that i believe was for the inverter anyway .
Wires go through the left rear seat gutter towards the jack storage point .
one plug gets connected onto the orphan plug you found in the back of the car ( that is the BCM control point i believe )
Then there is a plug for signaling and control that goes on the inverter along with the positive power input .
2 seprate sets of wired plug terminals leave the pigtail and energize 2 sockets ( one at the back of the car and one next to the usb plugs of the rear seats )
I cannot see what else could be there .
But i just need to see it on a vehicle to make sure .
If you can ask you dealer and he is able to provide some informtaion that would be great ! Lets see if anything of the above is wrong .
Yes i did , same with the cabby trim for the new socket .You got the bigger trim panel???
The parts catalogue states that the 2 inverters are interchangeable and the wiring harness has the same part number . Now i am not sure if down the line they discovered that that is not the case .I admittedly know very little about inverters and auto electrics in general so this might seem daft - NAS spec trucks like mine have the 400W inverter, can one just swap out the unit for a larger inverter since the wiring is already there? Or would the wiring in place not be beefy enough?
You use different wiring.I admittedly know very little about inverters and auto electrics in general so this might seem daft - NAS spec trucks like mine have the 400W inverter, can one just swap out the unit for a larger inverter since the wiring is already there? Or would the wiring in place not be beefy enough?
price wise was i think somewhere around 250 GBP once i have an invoice i will say for sure . Part number i am sure i have it somewhere i will try and find it for you .I would also like to know if you’ve got the price and part number for the larger left-side trunk trim panel that accommodates the inverter.
You different wiring.
I was answering Krabby question. Normally you use a different gauge because of the demand. I get what you are saying but I would check the gauge before I strap a larger inverter on the system.
13.5A is the best part of 2kw at 120v.![]()
Same. The 400W is not robust enough to do much more than power a laptop and a fan or a fridge. Trying to run anything more than a small , lower amperage device seems useless. I'm not exactly asking for Ford Pro Power hybrid solution, just something to be able to run a saw (13.5A) or a drill (10.0A) and Radio (Boombox) (4.A)
