I present the Auto Start/Stop Temporary fix
This cut off end of a cable tie has been working since November when I picked up my Quartermaster. Cost $0. Time 2 seconds.
Still waiting on my teenager to send me the file, but should definitely have it this afternoon. It's super simple, just an "L" shape in the right size to provide the friction to prevent the Start/Stop button from moving around. Same as all the other solutions. Just blends in a bit better if you care about that kind of stuff. ;-P
God damn.. I forgot to turn off auto start/stop yesterday.. was doing a 2 point turn in the middle of the road to reverse into my driveway. Fking engine stopped as I was turning the steering wheel and shifting into R, steering went stiff.. then .75 sec later car came back to life agin. All while in the middle of the road whilst trying to navigate this 2 point turn.
Again another example of sht programming to blame Ineos on. I mean there has to be a way to differentiate a gradual, straight stop to a red light, versus what I was doing - wheels turned, shifting to R, actively driving. You don’t turn off the engine in the latter scenario!
Guarantee these fkers didn’t test the vehicle for 1 million miles
Just how hard can it be to wait 2 seconds before activating? (As opposed to to 2 milliseconds)
But you survived. Be grateful for the little things.
? I was making a turn in the middle of the road. What should I wait for? Anticipation that the vehicle eagerly turns off, even in a situation that is not waiting at a red light?
You do know that when auto stop engages, you loose power steering? It’s fine if you are sitting at the red light, imagine you are briskly making 2 pt turn going from D to R while turning the steering.. and bam 💥 the fking engine turns off and you loose steering
I
I meant how hard would it have been for IA to set the timing for stop at 2 seconds vs instant.
I
I'd suggest that the engine should not turn off if your steering angle per the steering wheel is more than say 10° off center. This seems to be the situation that is getting so many people. It's certainly gotten me a few times before I added the clip to permanently disable it.
They can’t really be concerned with that.. their engineers are working overtime solving the jacket issue
Well I guess as long as they keep checking things off the list. Just hope the list isn't growing faster than they are working through it. 😬
Thanks, I might model something up in Fusion myself. Got a 3d printer for Christmas and just fixed two toys for my kids replicating broken or missing parts.
As a guy who has had 3D printers for close to a decade, this is not really a 3D print type job. Unless you want to make the part intrusive and oversized just because you want to.
I'd have to say the zip tie method is likely the absolute best solution I have seen so far and if I happen to lose my metal clip version I will likely just drop in a zip tie.
The zip tie or metal clip method is almost invisible.
Not to discourage, just suggesting.
This crap death of a 1000 cuts
Already did the Zip tie, it popped out, also hard to grab.
I don't know why you don't think this is a 3d print type job. I printed a tractor bucket that was 1/2 mm thick and it was crazy strong.
Appreciate the encouragement!
3d print something that you can screw into that square.
