HVAC system not working at all
Greenadier8
7:06 PM
Boise, ID, USA
On a trip in the mountains and my HVAC system is not working at all.
No heat or air. No blower fan.
Have tried the usuals turning off & on, turning key half way before starting to let things start. Nothing is working.
Help appreciated as we need heat to keep the windows from freezing.
Stu experienced something similar. He said 10 minutes with the car off cured it and believe it was a bubble in the heat exchanger which decativiates the entire HVAC system.
Upvote 0
What’s the procedure ? Haven’t tried that
You just turn on the car, and hold the button down and the screen will go blank and reset, if I recall correctly. Your mileage will disappear and be 0, but it comes back. You should be able to search that.
Upvote 0
It may be a failed blower motor, certainly not common at all, but possible
Upvote 0
Is the HVAC system on its own fuse? It may just be a fuse if a soft reset doesn't sort it
Upvote 0
You might try puling fuse FC11.
This is the EU fuse layout.
Upvote 0
Update: started working after sitting in the sun and got above freezing.
Anyone else experienced this?
If it happens again, disconnect/reconnect the negative terminal of the battery and see if that fixes it... i would also let your dealer know
Upvote 0
