High Beam Wire Location?
3:32 PM
Idaho, USA
I am having trouble locating the Yellow/Green high beam wire under the bonnet in my US, left hand drive Grenadier. Any help? Photos of the location?
Same here. I am also looking for the yellow/green wire.
Any updates here? I am looking for the same wire 😀
This is so smart. Thank you for giving me the idea...!
How many pins is in that dt connector?
I assume you just interposed at the connector to the lamp housing?
It is DT and not DTP? I'd like to order the connectors first before I open up the light assembly to map out which wire I need.
DT comes in 2, 3, 4, 6, 8 or 12 pin connectors.
I use DT for connectors under 10A in other parts of my car. I have a bunch of DT2 pin connectors.
If there is interest I can make a few more interpose cables. I won't setup a factory for it but I can make a few extra.
It would be useful if I could see a pic on what colors they are using in the bundle so I can order wire in the same color to make future trouble shooting a bit easier.
This is the plug that I used:
