Mine has no heated seats. I didn’t realize heat was an issue. lolMine is about the worst system I have encountered. Thank goodness for the heated seats I say.
Hopefully, you are in one of the warmer parts of the States.Mine has no heated seats. I didn’t realize heat was an issue. lol
That can’t be right, dealer must be telling porkies. If I switch to face only and turn up the temperature, I get hot air to face. However, if I switch to face and feet then I get warm air to face and cold air to feet (this should be incorrect and needs fixing).My dealer got back to me and indicated Ineos indicated heat was only intended to exit from the floor vents and windshield vents. The face vents not meant to have hot air.
Ha yep.. they told me the same.. so you have been able to get through the CO winter with this workaround? My IG doesn’t have heated seats. I figured the heat would work since it’s ICE. wtf ineos, get your sht togetherTry turning it on face and feet. Ours is lukewarm when just on face but if you go face/feet it gets nice and hot, just a quirk. Dealer said it was designed that way
