Heat 1st setting
MyIneos
4:45 PM
Texas
I have had issues with my A/C Heater since day one!! They fixed the issue when set on the second setting (face/feet) but now I’m having issues with the first setting (face only) when set to highest heat it only blows very lukewarm warm almost cold air in front and hot air in back
Welcome to the forum! Have you followed up with your dealer?
Not yet on this setting but they already fixed the face/feet setting! They had my car almost a month!
this is literally the same issue many people have.. all have been told "this is the way they are". Nothing to do.
I asked because I was wondering what the dealer did to rectify it for the previous issue... From what I've heard the usual fix is a new HVAC assembly as it is currently only sold as one part number for everything (although that may be changing?); it would be interesting to know if they replaced everything and then the new replacement piece had a different problem
It needs bleeding again, and if still not right, keep bleeding until it is. Make sure both reservoirs are topped up
CRH is right. You can go changing everything and it will be the same. I’ve had my fan motor assembly changed and it’s the same, same high frequency shrill noise on fan 4 too.
Just needs bleeding a couple of times. Top up with cold engine. It’s not perfect, it’s a bit slow but works.
Ideally I wouldn’t want anyone to dismantle my whole dash unless there is a proven fix. Last time, I had one bolt loose, a screw missing, a trim piece fixing missing after I dismantle it myself after a couple of squeaks.
Reactions: CRH
having similar issues.
Different temperatures on different setting and seeing a big difference in temp between front and rear.
Did yall top the coolant levels yourselves or just drop it off with the dealer? Were they aware of this issue?
Mine had bleed procedure done about 3 times by dealer and once by myself. It was on the final bleed when it needed topping up. Since then it works, yes it's a bit slow and can get confused but I'm guessing most of us are reaching that stage now so a bit of patience and understanding helps. Once you get heat properly you will learn how to deal with it's oddities
