As I mentioned before, I've used roof racks on a Range Rover Classic (aluminum gutter), Discovery 1 (Steel gutter) and Series (alu/steel gutter) - all of which could be considered flimsy - with no gutter failures. I expect the Grenadier to be more substantial or at least equivalent. I have had rack feet fail, most notably from carrying a 17-foot canoe where lateral loading and wind resistance can be very large.DaveB, so the three SUP boards basically created a sail that the gutters could not hold against the bow wave from the truck? Scary stuff! I've also not been impressed by the flex we've seen in the gutters.
I've had illegal loads on roof bars of my Disco 1 with not a hint of flex.As I mentioned before, I've used roof racks on a Range Rover Classic (aluminum gutter), Discovery 1 (Steel gutter) and Series (alu/steel gutter) - all of which could be considered flimsy - with no gutter failures. I expect the Grenadier to be more substantial or at least equivalent. I have had rack feet fail, most notably from carrying a 17-foot canoe where lateral loading and wind resistance can be very large.
I said that to a woman in a bar once.I must say that is a nice rack, much better IMO, good that they are utilising the roof bars also (?)
When my boys were young and we'd go to a LR Rally the Disco seriously looked loaded like the Camel Trophy!I've had illegal loads on roof bars of my Disco 1 with not a hint of flex.
Almost 30 years of use , not damage at all.
Are the Grenadier gutters aluminum, steel, or a combo?As I mentioned before, I've used roof racks on a Range Rover Classic (aluminum gutter), Discovery 1 (Steel gutter) and Series (alu/steel gutter) - all of which could be considered flimsy - with no gutter failures. I expect the Grenadier to be more substantial or at least equivalent. I have had rack feet fail, most notably from carrying a 17-foot canoe where lateral loading and wind resistance can be very large.
Hi, @das mo ,Just talked to BSI again. They created a high lift version of their feet that might fit my setup as additional support and take it to 5 feet each side. A, B and C being the gutter mounted DOT200 and the red marks being the spot for the BSI high lift mounts connecting to the bars.
But, was that said in rooftop bar?I said that to a woman in a bar once.
It didn't end well.
No, in the gutterBut, was that said in rooftop bar?
So many Dads up in here and so many Dad jokes. I've found my people.No, in the gutter![]()
I was trying to find it but no luckI wonder if you had any grab rail damage issues using the BSI rack as it is anchored whether IA would cover under warranty- not likely. Can anyone remember the load allowance on those rails? Was it 150kg?
I'm sceptical that the grab rail solution by BSI is within the design intent of the IG...I wonder if you had any grab rail damage issues using the BSI rack as it is anchored whether IA would cover under warranty- not likely. Can anyone remember the load allowance on those rails? Was it 150kg?
Does the full length roof rack rest on the roof strips? The brochure says the max static/dynamic ratings stated are achievable with it on (minus the weight of the roof rack of course).From the IA brochure descriptions, the roof load of 450kg static and 150kg dynamic was implied to be shared between the roof itself (on the roof strips) and the specialised gutter mount design where the weight is distributed .
No.Does the full length roof rack rest on the roof strips? The brochure says the max static/dynamic ratings stated are achievable with it on.
Denis - that can't be right otherwise the load would have to be spread across/held by BOTH rubber strips and gutters to achieve static & dynamic weight limits if not then you would need to deduct the weight limit for either one each was NOT carrying any weight?I'm sceptical that the grab rail solution by BSI is within the design intent of the IG...
IIRC the grab rail was designed for a tie down, not as a weight bearing entity.
Someone needs to hold a magnet to the Grenadier gutters.My old G wagen gutters had no flex at all and carried plenty of weight - they must be steel
