Grill lights
Desertfox
11:51 PM
Dubai - United Arab Emirates
Done! Connected to Ext 1 switch, taken power from under bonnet main power source, Ext 1 wires are on the driver side (left) contrary to some photos seen on the forum that show them on the right side. (must be wired different for vehicles with Aux battery, (I have only one battery). Original wiring taped and left unused. 2 hour fitting time. Noticed that the lights when fitted point inwards from both sides, due to bracket design. Good work by @grenadierworks . Very neat set of mounting brackets. The lights are very bright, for off road use only. Used the Yellow covers to test, ( both yellow and clear are included in the package). Tested
with headlights on full and all lights off and only the Grill lights on.
egattolin86
6:51 PM
Canada
Looks amazing! Did you buy an aftermarket kit to rewire them or can you just wire them to ext 1? Any video instructions out there?
