Don’t you guys have the option of real land cruisers over there, not the pseudo-land cruisers that we get here now?
In Cali there is a 10k dealer market adjustment which puts it at 79k before and additional add on.Interesting pricing for the Landcruiser in the UK. In North America the Landcruiser and the new Lexus GX have starting prices below the Grenadier. The GX 550 Overtrail starts at US$69,250 and the Grenadier US$71,500. In Alaska these are selling for a US$5500 Dealer premium over MSRP, and will probably stay that way for awhile throughout the USA.
Toyota will sell TONS of these…
And the B57 Grenadier engine is in a different class to the Toyota 2.8.
No your right mate, ive not been too active, had a lot going on this year (good and bad), but returning to some normality now!Hello buddy, not seen you about on here for a while. Good to see you commenting again.
(Or have I just not seen any of your comments )
You can get a proper 70 series un the UK, but its a a lot if you want a RHD..https://rowlandsandhordonautomotivesolutions.co.uk
£65k +vat for a V879...
404 Page | RHAS Toyota Land Cruiser Importer
Oops! That page can’t be found. 404 Back to home pagerowlandsandhordonautomotivesolutions.co.uk
BMW B57 and B58 are a full aluminium alloy modular engines.And the Lexus is not a 4-cylinder hybrid like the new 4 Runner and Landcruiser. The GX Lexus engine:
“twin-turbocharged and intercooled DOHC 24-valve V-6, aluminum block and heads, port and direct fuel injection
Displacement: 210 in3, 3445 cm3
Power: 349 hp @ 5200 rpm
Torque: 479 lb-ft @ 2000 rpm”
I’d prefer a compacted graphite iron block like BMW uses, but I wouldn’t doubt the durability of a Toyota powerplant.
Whats that? The 10yo yesterdays technology class? The LC is 15% lighter, and gets 60% better fuel efficiency. So much for blaming the crappy mpg on the grens weight.And the B57 Grenadier engine is in a different class to the Toyota 2.8.
Whats the iron block advantage? I thought the Gren block was aluminum anyway.I’d prefer a compacted graphite iron block like BMW uses, but I wouldn’t doubt the durability of a Toyota powerplant.
So when does you LC arrive?Whats the iron block advantage? I thought the Gren block was aluminum anyway.
The Landcruiser 300 doesn't have anywhere near similar payload or towing.Similar payload, towing, power, better fit and finish, an actual repair network, 10 more mpg (I'll put myself out on a limb and toss in less buggy).... We can talk amongst ourselves, but, to the emotionally detached that judges on how well something works, big "T" just laid down the law. The only reason the LC specs aren't even better, is they are having issues creating identities for an overfilled product line. The only company Toyota is competing against is itself, and oddly, it's winning.
You’re right, I stand corrected. I had read years ago that BMW was considering using CGI for the block so they could increase durability and longevity and use the same block for both the diesel and gas engines for economy of scale. Well apparently they are using the same blocks but determined closed-cell aluminum meets the demands instead.BMW B57 and B58 are a full aluminium alloy modular engines.
Yes, you’re correct, the BB57 and 58 are using aluminum after all. Engine manufacturers are finally using compacted graphite iron due it’s increased strength compared to regular cast iron, so they can make a block with less material and increased durability, saving weight and cost. The disadvantage for them is the increased tooling cost since CGI is much harder to machine than cast iron.Whats the iron block advantage? I thought the Gren block was aluminum anyway.
