Grenadier Regearing after tire upgrades
Kalthunayan
4:23 AM
Kuwait
Has anyone re-geared the transmission after increasing tire size? I have upgraded my tires from 265 to 285 and i was wondering if i should re-gear or not.
If you are only going up to a 285 it would easier to leave it and see how the car performs, it will most likely be ok.
There is nothing out there to regear the ZF transmission or the transfer case.
Regearing the differential may be an expensive option. The best source of information would be to approach Carraro directly with the information from the id plates on the axle and see what other crown wheel and pinion ratios are available for the Grenadiers axle configuration. Carraro is better known for tractor components so finding aftermarket gear ratios for the diffs could be very difficult. The other hassle would be finding a dealer or a workshop willing and with the tooling to regear a Carraro diff.
Upvote 0
Yeah i think just leaving it would be the best option. Although i did feel once the transmission shifts down gears especially in low speeds it does feel like the shifts are quite harsh. I don’t know if thats normal or not.
Thank you anyway.
Upvote 0
Thank you anyway.
Transmission shifting harshness won't be altered by changing the axle ratios. A clunky downshift (especially 3-2 or 2-1) is definitely a feature of the transmission
Upvote 0
I have it 80% of the time! Lemme know please if you do get a solution to make it smoother. I’ve tried resetting the transmission (mentioned in another thread here on the forum) but that didn’t work!
Upvote 0
I accepted it as a feature of the vehicle the first time I felt it, can't say I've looked or even wished for a "solution" to it. In general the Grenadier is more utilitarian than smooth as I would compare to a luxury vehicle, and that's perfectly fine with me
Upvote 0
My biggest problem with it, is, I've never had a truck where that want a precursor to problems. It's not a constant either, I can do the exact same stop twice and two different results. "Internet" points to the possibility the A clutch pack is not engaging fast enough. Maybe an aftermarket sport tune would purge the issue.
Upvote 0
I accepted it as a feature of the vehicle the first time I felt it, can't say I've looked or even wished for a "solution" to it. In general the Grenadier is more utilitarian than smooth as I would compare to a luxury vehicle, and that's perfectly fine with the thing
The thing is I’ve driven multiple grenny’s (dealer/friends) that don’t have it, they are much smoother. Only mine and couple I’m reading about in here!
I do understand that grenny’s are utilitarian and all, and I wouldn’t mind it, but knowing that my friends cars don’t have it makes me wonder!!
Upvote 0
For reference, my Gren does not have any of these shifting issues. At least not anymore. In the very beginning I most certainly had some aggressive shifts at lower RPM. Not sure what has caused it to smooth out. I doubt it's a programming issue though.
Upvote 0
Ours shows the occasional abrupt 3-2 downshift. It almost completely disappears when coasting to a stop with out the brakes applied. Firm shifts used to be considered a result of good condition clutches and adequate line pressures. Sloppy, lazy shifts indicate a worn transmission - or used to.
Upvote 0
Had the same harsh downshifting quality issues in lower gears for about the first 300 or so miles but after that things smoothed out considerably with no further clunking when slowing down. Most likely a combination of components bedding in and transmission software adaptations/learning would be my assumption.
Upvote 0
I did lift my grenadier (1.7" front 1.2" back) with bigger tires. although I felt overall the drive was better especially coming from a country where roads are terrible. off-road as well much better. the only slightly worrying thing is the regearing. I hear about it allot but I've never seen anybody try it out except for American made cars.
A Clunky downshift as @anand pointed out. I think it might be due to weight as I have a tent installed, bigger Mickey Thompson tires (Although I've heard they are quite light for their size) a fridge, and now about 120liters of water.
I do worry sometimes about the driveshaft after reading different posts about it failing after the Eibach lifts.
Upvote 0
I don’t like the 3-2 clunk either but I also don’t know if it’s the gearbox or t-case.
Upvote 0
