Hey Guys! AJ From GP Factor. Excited to be a part of this forum as a vendor and lifetime member!
If you are unfamiliar with GP Factor, we produce high end vehicle parts and camping gear in the USA. We have prided ourselves on making parts that do not compromise on quality, and provide years of hard use. We had announced earlier this year that we will be making a full line of parts for the Ineos Grenadier. Currently, we produce one of the best folding tables on the market. We are excited to announced and give you all a sneak peek to the version we will be releasing for the Grenadier! This table is currently based on the same proven design we have made for years for Jeeps, Campers, Broncos, and Land Cruisers. It will be sized and specifically designed for the Grenadier. The specs of this table for your Grenadier as follows:
  • NO drilling or modification. This will use the existing factory bolt riv-nut locations so installation is super easy. You could even use your factory mounting hardware.
  • It will come with our patented cableless hinge design that is both durable and easy to use.
  • Table is made from food Grade 304 stainless
  • One handed dual latch design for easy closing and opening
  • All tables include a ½” bamboo cutting board that can be removed for cleaning or flipped over for dual sided use.
  • We will be releasing a second version of this table that will have a compartment built into the backer (like the factory plastic piece)
FULL LISTING FOR THIS TABLE CLICK HERE: GP GRENADIER FOLDING TABLE
We will be opening up preorders for these in a few weeks and plan to ship the first batch in January/Early February 2024. I have also included in this post some pictures of our existing tables for reference.
You can also find a lot more pics, videos, and other media on our existing tables on our Instagram or website - @gp_factor
We will be releasing other products soon (maybe some stuff you all have been requesting…) for the Grenadier so keep an eye on our vendor area of the forum and also subscribe to our email list as well on our website – Gpfactor.com
Thanks and let me know if you have any questions! Cheers,
My table arrived today. It is exceptional and matches the interior so well that a neighbor thought it was OEM. Installed in a short time and love the look. Thank you for developing this nice addition to my IG.
Thanks for the kind words 🙏
Installed my table this morning. Took about 20mins taking my time. I couldn't be happier with the end result.
Exceptional design and build quality. I say this as a product designer and as someone who has bought/installed a LOT of aftermarket gear over the decades. @GPFACTOR should be proud of what they accomplished here. Packaging and hardware also top notch.
Some constructive input:
Would be nice to include a QR code for link to web-based instructions. Install was pretty obvious but it would add to the confidence factor. Also the packaging was good but you might consider some cardboard protectors be included on the ends inside the shrinkwrap. Mine had moved around inside the box enough to penetrate the wrap. There was NO DAMAGE but its something you might consider.
Well done!!
Well done!!
Definitely appreciate the feedback! Thank you!🙏🙏🙏
AJ, I'm adding the Luna Light for the cubby, it needs to be hard wired. Do you have a solution for that?
Yes, we have some pics of how one of our guys ran it through the wiring on the bottom of the door. Granted they had the inside panels off but that’s where they ran it. I have not personally done one yet so I won’t claim to know exactly where to wire it but I will try and post more info this week when I see his.
Thanks AJ - Any help is appreciated. Love the table BTY, best quality out of anything out there IMO.
Good Morning all,
In case you didnt see at Expo, We have made a few Fender plate kits for the Grennys. Standard and a Faux Vented version. Here are some of the details. Kits are available for preorder today and should ship in about 1.5-2 weeks. Cheers!
We have made these fender plates to be an easy install that does not require drilling holes in your vehicle. Unlike many of the options out there, we have made these out of a thicker 1/8” aluminum, with a matching textured powder coat that matches the bumper and other black parts on your truck. The plates are attached with a very specific 3M VHB 5952 double sided tape that fully ensures your plates will stay in place securely on your vehicle. Plates are manufactured with attention to many details including the welding of the foe vent filler plate, powder coat is only applied to the top and sides to ensure the base layer of VHB has the best adhesion to the raw aluminum of the plate, and a textured black finish that matches the rest of the vehicle. We have two options available for your Grenadier: Plain plates, and our faux vented plates.
Couple Notes as I am sure some will ask on the VHB: We worked with 3M to pick the most specific VHB for this purpose. Plates are properly taped prior to powder as this specific VHB is meant for adhesion of raw aluminum/metal to a clear coated paint finish. When installed properly on a clean surface, this is extremely durable.
Good Morning Guys,
This is more of a new Universal Product we released recently and not Grenadier specific, but if anyone is in need of a great Propane mount, Check it out. Cheers.
The Mount is made for 10/11 lbs tanks and will mount to just about any surface with a ton of mounting holes. If you see on the last pic, we will have a mount specific to the Grenadiers out soon for the rear doors that will hold it and that mount will also hold Rotopax and other stuff as well.
I see the wing tops have a UK price, but are these shipped from the UK or are they imported.
If they are imported, are there any plans to have a UK supplier ??
I ask as I have been caught with VAT at customs before and would prefer not to be caught like that again as it’s quite often the parcel company who act as the agent for customs and then add their nice little profit or should I say admin charge on the top.
Buzz Overland is our UK distributor and they have an order coming in to them in a few weeks with these included
Thanks buddy. Hopefully catching up with those guys next month 👍
Good Morning all,
We have another new product release this morning. Cheers!
We are proud to introduce another awesome accessory for your Ineos Grenadier, our Rear Door Accessory Mount! This mount required no modification to your rig, and mounts in the same spot as the factory ladder. This is a great add-on to your Grenadier if you do not have the rear ladder, and are looking for a great place to mount a variety of accessories. We designed the mount to be as low profile as possible so accessories like Rotopax and Propane tanks do not stick out past the spare tire. The mount is constructed of .125 Stainless Steel, with a durable Textured black powder finish. The Mount comes with a standard Rotopax Mounting pattern that can accept just about any Rotopax accessory, or other mounts (like our propane mount) that have that same pattern. The kit comes with spacers, specifically sized for each mounting hole. The spacers allow the mounting bracket to sit on the spacers , and not crush the rear door plastic panels or body on the bottom of the door. Included with the spacers for the mounting holes is a series of rubber O-rings to insure a proper fit to the factory mounting locations.
*ROTOPAX MOUNT NOT INCLUDED*
SPECS:
Material - .125 Stainless Steel / ASA UV Rated Polymer for the spacers
Finish – Textured Black Powder Coat
Hardware – Stainless M8 BH Screws, SS washers, Oil-Resistant Buna-N O-Ring
