Hey Guys! AJ From GP Factor. Excited to be a part of this forum as a vendor and lifetime member!
If you are unfamiliar with GP Factor, we produce high end vehicle parts and camping gear in the USA. We have prided ourselves on making parts that do not compromise on quality, and provide years of hard use. We had announced earlier this year that we will be making a full line of parts for the Ineos Grenadier. Currently, we produce one of the best folding tables on the market. We are excited to announced and give you all a sneak peek to the version we will be releasing for the Grenadier! This table is currently based on the same proven design we have made for years for Jeeps, Campers, Broncos, and Land Cruisers. It will be sized and specifically designed for the Grenadier. The specs of this table for your Grenadier as follows:
  • NO drilling or modification. This will use the existing factory bolt riv-nut locations so installation is super easy. You could even use your factory mounting hardware.
  • It will come with our patented cableless hinge design that is both durable and easy to use.
  • Table is made from food Grade 304 stainless
  • One handed dual latch design for easy closing and opening
  • All tables include a ½” bamboo cutting board that can be removed for cleaning or flipped over for dual sided use.
  • We will be releasing a second version of this table that will have a compartment built into the backer (like the factory plastic piece)
FULL LISTING FOR THIS TABLE CLICK HERE: GP GRENADIER FOLDING TABLE
We will be opening up preorders for these in a few weeks and plan to ship the first batch in January/Early February 2024. I have also included in this post some pictures of our existing tables for reference.
You can also find a lot more pics, videos, and other media on our existing tables on our Instagram or website - @gp_factor
We will be releasing other products soon (maybe some stuff you all have been requesting…) for the Grenadier so keep an eye on our vendor area of the forum and also subscribe to our email list as well on our website – Gpfactor.com
Thanks and let me know if you have any questions! Cheers,
Good Morning Grenadier Fam,
We are hosting with OK4wd a Grenadier and Coffee Event November 9th 8am-12pm up at OK4wd. So if anyone is interested, link is below. Cheers!
By my calculation we have no more than 4 days to wait for bullbar pics, since I believe GP-Factor said they would be posted in September. Let the countdown begin!
Very interested!
As promised in September! Preorders are open now - First Batch shipping middle to end of November. 4B6A8787.jpg
Introducing the GP Factor Ineos Grenadier Bull Bar Grill Guard. Our mission in designing this bull bar was to create a strikingly aesthetic yet robust and functional product for the Grenadier, and also fully made right here in the USA. The result is a uniquely crafted bull bar made from five separate pieces, rather than a single solid unit, allowing for enhanced versatility and ease of use. Here are some key benefits of our innovative design:
  1. Easy Replacement: Damage to the outer sections can be easily fixed by replacing only those parts.
  2. Versatile Options: Middle tube sections can be swapped out to accommodate various light mounting choices in the future.
  3. Effortless Shipping: Individual pieces make shipping simpler and safer, reducing freight costs and eliminating complications at the time of delivery.
  4. Enhanced Durability: Our multi-piece design is engineered for superior strength and longevity. Constructed from 3/16” (0.187) HRPO A36 Carbon Steel with 1.9” diameter tubing featuring 0.125” (1/8”) thick walls, this bull bar is built to withstand the demands of rugged use. The main pillars boast an I-Beam construction for added strength and an impressive look. With pillars and bar mounts all measuring 3/16” thick, when assembled, the combined thickness reaches 9/16”.
The bull bar mounts securely to the bumper using eight factory mounting holes on each side—four M10 in the front, two M6 at the top rear, and two M6 on the bottom—to ensure stability and support without any modifications required. All included hardware is crafted from A4 Marine Grade Stainless Steel with a Black Oxide Finish for superior resistance to corrosion.
Specifications:
  • Material: A36 Carbon Steel HRPO
  • Finish: Sandblasted, Zinc Primer, and Textured Black Powder Coating
  • Weight: Approximately 64 lbs
  • Origin: Full Made in the USA
  • Compatibility: Factory Bumpers with or without factory winches, and factory bumpers with GP Factor winch kits.
As promised in September! Preorders are open now - First Batch shipping middle to end of November. View attachment 7871700
Specifications:
We have a winner! Looks good!
Looks good, but I am not a fan of bolt-together, especially thinking of minimal body damage in an animal strike. How would you expect this to survive compared to the welded factory bar?
Specifications:
A J, that looks great, and I see from your website shipping is free in US. The price of $1,800 seems good as well. The US Grenadier configurator still doesn’t show a bull bar option but rumor is it will in the spring. The Aussie configurator shows a roo bar cost of 2,510 $Aus, about $1,731 US. For us considering the GP Factor bull bar vs OEM, is there anything else you can share comparing the two?
Its bolted together with 4 M12 bolts and the brackets for those are captured in the pillars. I can tell you from seeing the factory bar, its going to be as strong if not stronger due to the proper welds, materials used, thickness, and hardware used. The welds on the factory bar, which has a completely hollow pillar, are less than stellar imho.
yeah so we wanted to price it so it was not more expensive. $1799.99 and free shipping.
As far as a comparison: Not sure what materials are used or what steel is used for the factory bar, but it is 100% made in China. Ours is fully made in the USA. The factory pillars are hollow, and it is definitely massed produced as far as the welding quality from the ones that I have seen. Welding can go either way. I have had some pretty crap weld jobs done for me in the past and stuff breaks easily if not done properly. We have one of the best welders in house with over 20 years of experience that made sure these are welded for maximum strength, durability, and astheticis. Not sure what the finish is on the factory one. We sand blast, zinc primer, and text black powder. All the hardware included is A4 Marine grade stainless. M12 bolts for the brackets, and New M10 screws and M6 screws for the bumper.
If that's a concern add a couple more 12.9 fasteners 1/4 in from the front and you'll tear the welds or upright plate before you snap the fasteners.
Looks great, A.J. Well done. I'd love to see a pic of the five pieces of the unit separated so that I can better visualize how everything comes together.
Looks really well put together! I like the design a lot.
Its super tempting to put in an order.... I'll decide tonight.. :)
