Hey Guys! AJ From GP Factor. Excited to be a part of this forum as a vendor and lifetime member!
If you are unfamiliar with GP Factor, we produce high end vehicle parts and camping gear in the USA. We have prided ourselves on making parts that do not compromise on quality, and provide years of hard use. We had announced earlier this year that we will be making a full line of parts for the Ineos Grenadier. Currently, we produce one of the best folding tables on the market. We are excited to announced and give you all a sneak peek to the version we will be releasing for the Grenadier! This table is currently based on the same proven design we have made for years for Jeeps, Campers, Broncos, and Land Cruisers. It will be sized and specifically designed for the Grenadier. The specs of this table for your Grenadier as follows:
  • NO drilling or modification. This will use the existing factory bolt riv-nut locations so installation is super easy. You could even use your factory mounting hardware.
  • It will come with our patented cableless hinge design that is both durable and easy to use.
  • Table is made from food Grade 304 stainless
  • One handed dual latch design for easy closing and opening
  • All tables include a ½” bamboo cutting board that can be removed for cleaning or flipped over for dual sided use.
  • We will be releasing a second version of this table that will have a compartment built into the backer (like the factory plastic piece)
FULL LISTING FOR THIS TABLE CLICK HERE: GP GRENADIER FOLDING TABLE
We will be opening up preorders for these in a few weeks and plan to ship the first batch in January/Early February 2024. I have also included in this post some pictures of our existing tables for reference.
You can also find a lot more pics, videos, and other media on our existing tables on our Instagram or website - @gp_factor
We will be releasing other products soon (maybe some stuff you all have been requesting…) for the Grenadier so keep an eye on our vendor area of the forum and also subscribe to our email list as well on our website – Gpfactor.com
Thanks and let me know if you have any questions! Cheers,
Happy Friday, Figured I would give you guys the heads up first. We have some scratch and dent / demo Grenadier tables available in ou scratch and dent section on our website available. There is a couple flat and a cubby table in there. We put up product periodically at good prices, so first come first serve. All the products function as they should. Cheers guys
Good Morning guys,
In case you don’t see the other thread where I posted this, you guys are getting the first sneak peek (outside of a couple
Instagram random posts - also if you want to get the first view of new stuff, definitely follow our Instagram stories). Our full winch mount kit is being launched shortly. Fully integrated into factory bumper, 12.5k winch and over 60ft of synthetic line. Replacement internal bumper is full 1/4” steel construction so it’s much stronger than the factory options. More specs to come next week.
I'm seriously looking this design. Would love to know what winch you're adding and what winches may fit.
My understanding is the winch is come up that was designed especially for this set up.
Good Morning Gents!,
We are proud to finally announce and release for preorder our 12.5 Hidden Winch Mount. Here's the info and dont hesistate to ask questions. ill be on here most of the day to answer. ALL ORDERS PLACED ARE PREORDERS IN THE FIRST BATCH. WE ANTICIPATE TO SHIP THE FIRST BATCH END OF SEPTEMBER - FIRST WEEK OF OCTOBER 2024. ALSO, The FORUM DISCOUNT WILL BE AVAILABLE TO USE FOR THIS DURING THE PREORDER PERIOD. WE WILL ALSO BE INCLUDING A SPECIAL GIFT INCLUDED WITH ALL PREORDERS PLACED WE WILL SHARE NEXT WEEK!IG-0200-11-WEB.jpg
Cheers!
This kit seamlessly integrates into the original bumper shell, preserving the vehicle's stock appearance without requiring any alterations. Featuring the robust Come Up 12.5k SealSlim winch, equipped with 65ft of synthetic line (55ft usable), Increasing the length of the usable line over the factory winch by 83%, ensures you're prepared for any off-road challenge.
Included in the Kit:
GP Factor Winch Mount, Fairlead, Hardware for Installation, Come up Seal Slim 12.5 RS Winch.
Specifications for Winch Mount:
Material: Constructed from full 1/4" steel, ensuring durability and strength.
Finish: Coated with Zinc Primer and finished in textured black, providing both corrosion resistance and a sleek factory appearance.
Fairlead: Proprietary 6061-T6 2.25" thick Billet Aluminum fairlead with Type 3 Hardcoat Grey Anodized Finish
Fitment: Compatible with all Ineos Grenadier Models featuring the factory metal bumper. Maintain its original aesthetics
Winch Mounting Configuration: Foot Foward
Weight: Approx 100 lbs for winch mount and winch - (Removal of the factory internal bumper will make your net weight approx 70lbs added)
Specifications for Come Up Seal Slim 12.5 RS Winch:
*THIS WINCH IS ONLY AVAILABLE IN THIS KIT AS IT WAS SPECIFICALLY MADE TO FIT THIS KIT, VEHICLE AND PER THE SPECIFICATIONS NEEDED.
  • Rated line pull: 5,670 kg / 12,500 lb single line
  • Line speed ( 1st layer): 7.7 mpm / 25.3 fpm 45 A at 12V no load
    0.9 mpm / 3.0 fpm 470 A at 12V full load
  • Motor: 3,730 w / 5.0 hp 12V series wound
  • Gear ratio: 3-stage planetary 225:1
  • Clutch (freespooling): Rotating ring gear
  • Brake (outside the drum): Automatic, full load CBS (Cone Brake Structure)
  • Winch construction: Aluminum die cast housings with steel drum
  • Drum size: 63.5 mm x 227L mm (2.5” x 8.9”L)
  • Control: Both built-in digital two way signal wireless remote control and waterproof remote with thermometric indicator LED w/ 5 m (17') cord
  • Rope type: Synthetic rope
  • Rope size: 65' - (55' Approx Usable)
  • Mounting bolt pattern: 254 mm x 114 mm (10” x 4.5”)
  • Mounting : Foot forward mounting workable
  • Finish : Matte black powder-coated
    * Remark: Only foot forward mounting can meet SAE J706
Hey AJ,
Do you think that the kit for the trunk would be compatible with something like this door?
I have a basket on the side in the trunk and I can't really open the cover easily. I'm thinking about getting this door and with your kit it makes even more sense to me to get it.
Ready to place an order/ preorder for the Hidden winch mount kit, but have to ask: how simple is the installation and wiring? Supplied instructions adequate for someone new to winches and their installation?
I don’t want to make it sound easy simply because I’ve done in 12-15 times already lol. The perceived simplicity is sorta subjective to be honest. So I’ll try to be objective for ya. For most that have done installs of their own, it’s very simple, takes about 5-6 hours. The big chunk of time is due to taking the factory bumper apart and headlight and putting it back together. Very little modification is done so it’s mainly just a lot of taking apart and putting back together. If you don’t feel comfortable nor haven’t done one before or anything like this, I’d definitely recommend having a shop do it for piece of mind. And we can certainly recommend good shops across the USA and the UK if needed. We should
Have the full install instructions out in about two weeks or so.
Thank you for the frank reply as to the length of the job! If the install instructions include some video/ images along the way, that would be tremendously helpful in determining if I need to pay for 5-6 hours of shop time, or enjoy a day of bonding with my vehicle...;)
Yeah we will 100% of written instruction s with detailed pics we are formulating right now. But will try and have some good videos as well.
