Hadn't seen that. They told us the hood latch was broken so we couldn't see under the bonnet. I expected more free space under there!
ADVAW8S said:In Seattle, I asked one of guys there who does all the maintenance on the US car about adding a compressor under the hood. He said it would be very tight and closest option would be passenger side but that is a big might depending on size of compressor.
Paachi said:I am not the biggest fan of putting an air compressor under the hood. It gets dirty and hot under there. I like the idea of under the passenger seat. I was also thinking the space in the rear where INEOS had designed an externally accessible 'wet gear' compartment (near the gas filler cap) in the initial prototypes, might be a good location. You could access it internally by removing a trim panel and installing the compressor there. Use up the dead space and it should be cleaner and cooler there.
