Long Story short. My last post showing my front drive shaft broken in Glamis, since Ineos doesn't want to cover it under the warrantyI took my car to Agile Offroad for some better aftermarket solution.
Please note: All products installed on my car is still a prototype.
John Brindell All thanks to Agile Offroad!
I have both front and rear draft replaced with a U joint solution. The only cons is if you fully release the gas pedal at 70mph or higher you will hear some noise like 'Voom Voom' from the drive shaft. Other than that, no vibration or noise for other situation. If you lifted and also have 35 tire on your Grenadier I recommend you replace the factory CV joint.
They also helped me to reuse the rear shaft CV joint to replace the broken front one, now I have a factory front drive shaft as a spare. ( Note: Dealer is charging $1300 for the whole front drive shaft).
One more modification I have is the rear sway bar air link. It definitely will give you more flexibility when you on trail! Looking forward also get the front one!
It's a fantastic experience to work with Agile Offroad to get on the ground and resolve some real offroad issues for the Grenadier!
