Front Drive Shaft Update
6:48 AM
San Jose, CA
Long Story short. My last post showing my front drive shaft broken in Glamis, since Ineos doesn't want to cover it under the warrantyI took my car to Agile Offroad for some better aftermarket solution.
Please note: All products installed on my car is still a prototype.
John Brindell All thanks to Agile Offroad!
I have both front and rear draft replaced with a U joint solution. The only cons is if you fully release the gas pedal at 70mph or higher you will hear some noise like 'Voom Voom' from the drive shaft. Other than that, no vibration or noise for other situation. If you lifted and also have 35 tire on your Grenadier I recommend you replace the factory CV joint.
They also helped me to reuse the rear shaft CV joint to replace the broken front one, now I have a factory front drive shaft as a spare. ( Note: Dealer is charging $1300 for the whole front drive shaft).
One more modification I have is the rear sway bar air link. It definitely will give you more flexibility when you on trail! Looking forward also get the front one!
It's a fantastic experience to work with Agile Offroad to get on the ground and resolve some real offroad issues for the Grenadier!
given the front sharp angles, why a single double U-joint and not a double/double one?
I think it would be very difficult to get single or double/double u-joints of any configuration to run as smooth as the Rzeppa style CVs fitted on the Grenadier. The most obvious angles everyone is concerned about is the vertical angles brought on by suspension lifts. However, if you look underneath the Grenadier down the centerline of the vehicle front to rear you’ll notice there are fairly obvious lateral angles involved as well between the transfer case and front/rear differentials. In effect, you’d are asking a standard u-joint to run smooth while faced with compound angles both vertical and lateral at the same time.
Unless all the angles are engineered and balanced out perfectly a cross the entire drivetrain all u-joints style driveshafts installed on a Grenadier will either vibrate or offer a harmonic resonance at some point. The only joints able to handle both vertical and lateral angles simultaneously without vibration is Rzeppa style joints and is the most likely the reason IA went with them for the Grenadier and how the drivetrain is packaged.
It might be possible to get u-joints to run smoothly over a certain speed range but at some combination of speed or load you are going to feel them going about their business. It comes down to the severity of the vibration (potential extra wear on transfer case and diff input bearings, etc…) and whether or not the trade-off for stronger joints off-road is a bigger priority.
Unless all the angles are engineered and balanced out perfectly all u-joints style driveshafts will either vibrate or offer a harmonic resonance at some point. The only joints able to handle both vertical and lateral angles simultaneously without vibration is a Rzeppa style joints and most likely the reason IA went with them for the Grenadier. It might be possible to get u-joints to run smoothly over a certain speed range but at some combination of speed or load you are going to feel them going about their business. It comes down to the severity of the vibration and whether or not the trade-off for stronger joints off-road is a bigger priority.
Completely agreed! The stronger joints is way important for me since I don't want the CV fail again on the trail. Doesn't matter how you instal the lift kit, the CV will fail on this front draft eventually.
Mods- any chance we can move this to the “
Transmission, Transfer Case & Axles”​
Ties into a lot of the recent discussions there
Done! Thanks for the suggestion!
HEY DEREK - ANY UPDATE FOR US? HOW IS THE NEW DRIVE SHAFT HOLDING UP?
Update on potential new fix coming out next week:
Was at a 4WD show yesterday and spoke to a JMACX installer and they stated that JMACX are introducing a new solution to their kit to address the front drive shaft angle, will be interesting to see what they've done! They said it will easily support up to a 3" lift. Can't imagine it being cheap though as their stuff is premium and already start from 6k AUS for the grenadier.
Maybe an axle housing with +3* built into it?
I don't think the offet laterally is creating the issue. There can be an offset left or right and the X and Y can be parallel, producing like angles. I asked John of Agile on one of his FB posts if he had compared the angle of the pinions and the tcase relative to one another, because I was concerned the tcase would point downward (rear) like a tradinal 2wd/4wd case, creating a mismatch in angles between the front case and front pinion. At the time, he said he had not looked at that and did not know. When I look at it, it "appears" to me to be the case and I have my offset bolt cranked all the way for better caster, which will pint the front pinion down a little more than factory. (In a traditional 4x4 the front shaft rarely spins much and rarely at high speed, so favoring the rear shaft alignmnet prolongs longevity of the system as a whole... or so it was explained to me years ago by someones wife... that was old)
this is an airLynx made to the Grenadier specs with mods to the rear skid plate. The airLynx softens the bar, and allows you to adjust the sensitivity.
The Grenadier rear links will be released next week and fronts in about 6 weeks.
View: https://youtu.be/UH48kqqucdY?si=cbsPHqHxnO-xqWY6
Hi Derek. Did you need to chop out some of the rear skid plate to gain access to the valves? I was wondering if they were going to bring this out for the grenadier as it looked a little awkward to get access to disconnects in the rear.
Cheers
Clint
Per the photos there are single cardan u-joints on both ends of the front and rear drive shafts. For this to run smoothly the angle of the joints at the pinion and the transfer case must match in order to cancel out the oscillation. If the angles do not match then vibrations are inevitable at certain speeds. Dialing in this angle on the rear shaft using adjustable control arms (Metalcloak potentially) should be relatively straight forward. But on the front this is likely impossible because of the need to maintain an already minimal caster angle.
A front shaft with a Rzeppa at the pinion and a double cardan u-joint at the transfer case is the type mostly likely to run without vibration while eliminating the problem Rzeppa at the transfer case. This type of shaft is angle agnostic. I have yet to see this configuration implemented on the Grenadier. I have a long standing relationship with a custom driveshaft builder in my local area and might have to contact him about building a shaft of this type for the Grenadier.
