Floor trim to access wiring tray
Cam
1:51 PM
Brisbane QLD, Australia
Any ideas how to remove this piece under the plastic floor trim.
Removal of bolts yields little movement or release in any obvious way.
I want to run some wiring inside through to the rear (UHF Antenna cable).
Maybe I'm missing something, maybe there's a better way?
Any help is appreciated.
Cam
Hi @Cam
Remove the floor mats then remove the base "lino" floor covering as if you were trying to access the drain plugs in the floor. There's a second lot of nuts (x2 in the front section -10mm socket) under the "lino". Same further back beside the front seat and the door sill in the passenger section...20230927_103904[1].jpg
Hi @Cam
Remove the floor mats then remove the base "lino" floor covering as if you were trying to access the drain plugs in the floor. There's a second lot of nuts (x2 in the front section -10mm socket) under the "lino". Same along beside the front seat and the door sill in the passenger section...
Thank you!!
