Extra Wiring Front Kick Panels
Steve A
8:11 PM
Grapevine, TX, USA
A while back there was a thread about the extra wiring behind the front outer kick panels that I think are switched but my search foo is not finding the thread.
My goal is to install some electrical outlets USB and cigarette lighter.
Thanks
Also download a copy of the Rok Dr Guide for switches used, fuse locations, etc Items 1, 4, 9 and 10 may help.
PLACE TO START FOR NEW OWNERS
  1. Download and use the Rok Dr Guide here. Print out a copy and keep it in the car;
  2. Grenadier Accessories (huge selection) for you to buy here;
  3. Kanvas bags and products here;
  4. Information concerning Deutsch DTP plugs here;
  5. Learn more about the CTEK SMARTPASS 120S and 250SE here;
  6. Fuse and relay thread here;
  7. Suggested Grenadier or QM fuses spares kit here;
  8. Littelfuse FHZ busbars used in the Grenadier here. It also informs you where all the busbar cables go;
  9. Finding the aux power outlets in the footwells here;
  10. Table describing all the available wire ends here and here (more wire ends if you selected the high aux power option);
  11. Various recommended torque settings here;
  12. Tool kits for the Grenadier/QM discussed here and here;
  13. L track information here;
  14. Oil filter part numbers and third party filters here;
  15. INEOS Air filter parts numbers and cabin filter here;
  16. Filter for Diesel water separator here;
  17. Understanding the NATO plug on the Grenadier here;
  18. What do you use on bolts/screws to stop corrosion, galling and seizing here;
  19. Guide to terminal crimping here;
  20. Anderson plug pitfalls here;
  21. Outback driving tips here; and
  22. Cheap battery monitors here.
This ought to be put in a MASTER DOC pinned thread at top of forum.....and as people identify fixes, replacements, etc....add them in
Items are being added over time. I customized the list above for this thread. The complete list is actually (copied from this master thread):
  6. Understanding battery chargers and how to use them (they do more than any alternator) here;
  7. Fuse and relay thread here;
  8. Suggested Grenadier or QM fuses spares kit here;
  9. Littelfuse FHZ busbars used in the Grenadier here. It also informs you where all the busbar cables go;
  10. Finding the aux power outlets in the footwells here;
  11. Table describing all the available wire ends here and here (more wire ends if you selected the high aux power option);
  12. Various recommended torque settings here and here (with Torque Table). General torque values (not INEOS specific) here;
  13. Tool kits for the Grenadier/QM discussed here and here;
  14. L track information here;
  15. Oil filter part numbers and third party filters here;
  16. INEOS Air filter parts numbers and cabin filter here;
  17. Filter for Diesel water separator here;
  18. Understanding the NATO plug on the Grenadier here;
  19. What do you use on bolts/screws to stop corrosion, galling and seizing here;
  20. Grenadier Fluid Specifications PDF download here;
  21. B58 Engine Reference Manual here;
  22. Guide to terminal crimping here;
  23. Anderson plug pitfalls here;
  24. Outback driving tips here; and
  25. Cheap battery monitors here.
INSTALLATION (OR HOW TO) GUIDES
  1. SEAT COVERS: Canny Outdoors video fitting seat covers here;
  2. SPOT LIGHT REPLACEMENTS: Mounting Kit of Exezit Lights here and KC Hilites here (new Laser Lamps Kit also announced);
  3. SIDE MIRRORS: Installing SUMA Performance side mirrors here;
  4. WORKLIGHTS: XHQ Work light here, with installation instructions here, STEDI Work light here and here;
  5. RETROFITTING A RED WINCH: Installation guide here;
  6. RETROFITTING 300W INVERTER look here. Thanks @landmannnn;
  7. REAR ROOF SHELF: Canny Outdoors video installing KAON rear roof shelf here and a Travel Buddy oven fitted to a rear shelf here;
  8. ROCK SLIDERS (ABNTR4X4): Installation video for ABNTR4x4 Rock Sliders here, with suggested improvements for tougher environments here;
  9. ROO BAR: Installing the Roo Bar here;
  10. ROO BAR LED LIGHTBAR: Installing a 20 inch Lightforce Viper lightbar under the Roo Bar Hoop here;
  11. UHF (CB) RADIO: How to install a UHF (CB) Radio in an INEOS Grenadier without drilling any holes here;
  12. UNDER-BODY ARMOR (RIVAL): Installing Rival under-body armor here;
  13. UNDER-BODY ARMOR (CUSTOM OFFROAD) BASH PLATES: The installation thread is here;
  14. UNDER-BODY ARMOR (CUSTOM OFFROAD DIFF PROTECTORS): Installing the diff protectors and trailing arm protectors is here and the PDF here;
  15. UNDER-BODY ARMOR (ERO FLO FUEL FILTER GUARD): The installation thread is here and the PDF here;
  16. SIDE STEPS: Electric side steps installation guide here;
  17. CHANGE WHEEL BEARING OR STUD: how to change a front wheel stud or wheel bearing here;
  18. INSTALLING AFTERMARKET SPEAKERS IN FRONT DOORS: instructions here, German language install here;
  19. INSTALLING BLACK SHEEP NUMBER PLATE HOLDER (US/AU models with OEM winches) here;
  20. INSTALLING REDARC TowPro Elite3: look here;
  21. INSTALLING THE WOLF G900 DASHCAM: Loc Nar's detailed installation guide here;
  22. B PILLAR (DISASSEMBLING): look here with detailed instructions here;
  23. REMOVE RAISED INTAKE and replace with grille here;
  24. INGEMAR’S GRENADIER HOW TO SERIES here and here (e.g winching, offroad modes, diffs, etc);
  25. INEOS FORUM resources here;
  26. INEOS Fitting Guides here, at least 9 guides from INEOS and Rhino Rack.
