Drive shafts maintenance
ORSO
11:01 AM
Italy
Hi, I know well the land drive shafts with cardon joint and greaseable crosses.
Those of the Ineos looks different. They looks homocynetic. Are they greaseable?
With the automatic gearbox, how can you put the vehicle in neutral to make them turn?
Thanks.
I think you may be referring to a "homokinetic" or "constant velocity" joint? They are enclosed in a rubber boot with grease and do not require regular lubrication so long as the boot is intact and properly sealed ...
That recent video with those South African guys (descriptive I know) asked about flat towning. The Ineos rep mentioning a 13mm bolt on the transfer case would disengage the drive shafts.
There's ref. to this on p117/118 of the English version of the Owner's Manual. In addition to unlocking the centre diff with the transfer case "neutralisation bolt" , both front and rear drive shafts have to be disconnected for longer tows!
That is disappointing.
It's odd it has a warning about removing the propshafts but does not mention them in the actual procedure for towing?
I would have thought just disconnecting them at the axle ends and securing them safely would be enough.
Also if the propshafts are removed then why is the towing distance limited to not
more than 3 miles (5 km)?
And if the propshafts are removed why bother with neutrals on gearbox and transfer case?
Good point
In the first video Q&A they said it could be flat towed. I specifically asked the question. There are plenty of automatic vehicles that can be flat towed 4 wheels on the ground. I have to say I am disappointed if it requires more than sticking it in neutral.
ok, but how long will the original propshaft grease last?
sooner or later they will have to be greased, but how often?
Probably about as long as the grease in 4runners front half shafts. About 150k miles, and then only because the boots deteriorated.
Bonjour à tous
Il semble que les Grenadier en version Trialmaster soient équipés de protection de pont et de plaques de protection de la transmission
Arrière
Avant
Ces protections ne semblent pas être en place sur la version Fieldmaster.
Est-ce confirmé ?
Photo of front prop shaft:
I was slightly surprised to see the angle the differential nose makes with the propshaft, especially as the axle appears to pointed downwards and so making the join angle greater?
