Door rubber seals
C64_forever
5:44 PM
The Bay Area, CA, USA
Hello esteemed Grenadier brothers and sisters,
Several door rubber seals are coming unglued. Does anyone here have a suggestion of what glue should I use? Thanks much in advance.
I do not glue them but use a dynamat roller to keep them in place (every so often).
Press firmly not hard when doing it. I found parts of my seals not correctly in place. The roller fixed that.
Photo and more details here.
dynamat-roller-jpg.7851231
I used 3M power tape.
My dealer "re-stuck" mine under warrantee. I can tell you they are very well adhering now, so whatever they did worked like a charm :)
Loctite 406 as per the TSB… be very careful using it and don’t get it on anything you don’t want stuck including your own fingers then use the restroom. My doctor says the skin should grow back more or less :)
I am having all 4 doors (possibly tail gates) rubbers replaced end of Jan 2025. Going in for a two-day session at the dealer. I have a few things in need of fixing.
