- Local time
- 8:42 AM
- Joined
- May 19, 2022
- Messages
- 2,227
This morning I finally had time to try out the off-road mode, the gear reduction and the locks.
High-Low and the centre diffential lock work, even though everything is still very stiff and you have the feeling that shifting is not good for the mechanics.
I had problems with the rear lock. I tried to switch it on according to the manual. However, the LED in the switch kept flashing instead of lighting up permanently after driving forwards and backwards as described.
In addition, there was a yellow symbol for the rear axle lock and a yellow caution triangle in the front display.
I undid all possible switches and switched it on again. But there was no change. After pressing the button again, the display turned flashing red, together with the yellow triangle. However, the LED in the switch went out.
The front axle lock could not be engaged. I therefore assume that the rear lock is also not engaged.
But who knows. It's the weekend and I can't reach the dealer or anyone competent at INEOS.
Have any of you had the same experience? Are there any ideas? Thank you.
