Diff Lockers unlock on their own??
Tinerfeño
2:25 PM
San Juan de la Rambla, España
Hi, Myllis!
My guess: The teethed part (that changes position) has splines on the drive shaft (Am. half shaft) and in locked condition connetcs the drive shaft to the differential cage.
Clark Kent
12:25 AM
Toowoomba QLD, Australia
I wonder if anyone is familiar with the operation of the Grenadier axle locks. Ineos says the switch is electronic (i.e. the one's on the roof), but the lock itself is mechanical. Attached are two photo's, one with the lock open and the other one, the lock closed. The only difference is the 10% rotation change of the "front pressure plate ????", photos doesn't really tell you what actually locks the crown gears? Nor does it tell you how the information about pressing the button in the cabin comes to the locker?
Has anyone measured the diameter of the Grenadier Trialmaster shaftaxle and how many splines shaft has?
Hi @Myllis
Actuation is done by an electromagnet hence the e-locker name. Lock and unlock requires a small rotation of the wheels to drive a locking pin along a ramp.
A single wire circuit connects to each axle housing. Operation of the overhead switch applies power to the electromagnet to lock (provided the conditions for locking are met as per the owner's manual). Removal of power deenergises the electromagnet allowing the diff to unlock.
Watch the Harrop video here.
The Grenadier uses the wheel speed sensors to confirm lock and unlock. When Lock is selected the switch light will flash until a signal is received to confirm that both wheels on that axle are rotating at the same speed, i.e. the axle is locked. Same for Unlock which can cause a delay between selecting Unlock (off) and the light ceasing to flash. The delay is waiting for the wheel speed sensors to detect a difference in wheel speeds across the axle. The vehicle needs to be driven a short distance in an arc to cause the wheels to turn at different speeds.
I have no info on the axle shaft diameter or spline count.
