Deutsch DTP plugs
Cheshire cat
12:48 AM
Cheshire, UK
So attribution is important if you claim an image is yours, or you wouldn't bother correcting me at post 232, but you're happy to lean on the forum rules to use an image contributed by someone else? Attribution is about acknowledgement of the work done by others which makes this forum such a valuable resource.
You took similar offence at @DCPU when he called you out for the same thing previously which resulted in a series of ugly exchanges between you, Stu, Krabby and DPCU. Based on the treatment he received in that exchange he withdrew at his choice from making further contributions to the forum - to our collective loss.
Goodbye.
DCPU backing out was a big loss to most of us on this forum. His contributions, along with others, was invaluable.
Psignore00
7:48 PM
Apollo Beach, FL, USA
I have found it very hard to find someone local to build the connectors, even if I buy them from Agile Offroad.
Everyone tells me it’s special and they aren’t specialized for it. Even the dealer said they couldn’t, but would facilitate a partner vendor doing the work if given enough lead time.
I guess I was expecting to be able to run down to Napa or AutoZone or order easily on Amazon a pair of pigtails with the connectors built in
I am planning to have the dealer facilitate crimping a set of 4 quick connects and the NATO adapter wired to an Anderson plug quick connect to power the winch from the rear hitch.
TheDocAUS
11:48 AM
Eromanga
If you have the plugs and pins/sockets from Agile Offroad, it is easy to make your own. The only extra thing you need is the crimper and I saw that on the Agile Offload website. Before buying confirm that crimper is for the DTP size pins and sockets with Agile Offload (the description is silent on the size). DTP pins/sockets use a Size 12 crimper. Technical information on Deustch plugs and part numbers is located here.
It is not really specialised, you just need the right parts, tools and technique.
WARNING: the following Wurth video is using Deustch DT plugs, the Grenadier uses the larger Deustch DTP plugs. So your plugs and crimper must be DTP size.
deuplugs-jpg.7808047
View: https://youtu.be/GQs7EPzDOak
Tom109
7:48 PM
It is super easy to work with DT and DTP connectors, you only need the specific crimping tool. Since you're in FL, try a marina. DT plugs are common for bilge pumps, etc.
11:48 AM
...and loads of you tube how to vids if you search DTP or DT plugs
CloudVisual
12:48 AM
Can anyone help me with finding a part number for the covers that protect the DTP connectors on the outlet of the roof? I bought my Grenadier used and doesn't have the aux power out to the roof, so I'm going to have to retro fit this. Would like to do this as close to the original spec as possible.
I have a 3D printer if someone has an STL
TheDocAUS
11:48 AM
Eromanga
EDIT: Sorry I think I misunderstood the question. I think you mean the black cover and I cannot help with that part number. The quickest way will be to ask the dealer, and then post it here. The "cover" consists of two parts, the base and the outer cover, base visible in the picture below. Let us know if the two halves use the same part number, thanks.
The "blank" has two parts:
1. the plug which is DTP06-2S;
2. plusa two white seals. The same size seal fits into a DTP or DT plug end.
Look at right side of this image. Parts numbers are marked. Whole thread on DTP plugs here.
20230303-open-cap-deutsch-connectorlabel-jpg.7814124
euroflo
10:48 AM
Dayboro QLD, Australia
I have just done the same thing... they come in 2 parts
the base and the cover...
the cover is listed in the trim section on there parts section
whilst the bottom part is in the electrical section list I believe...
will see if I can find the invoice to get the part numbers
was going to 3D print some myself, but they are not that expensive
PDX_Keith
4:48 PM
Portland, OR, USA
I had my crimper die go MIA in the dark abyss of my garage when I took it apart to change diameter die. I just soldered the wires into the DTP pins and it works great. I personally think for the low amperage connectors it works better.
