Can the detachable rear winch also be used in the front?
If you have the front hitch plate, then yesCan the detachable rear winch also be used in the front?
Now that you mention it, I vaguely remember something about that... A quick look at the MY24 configurator for the RoW shows that the front hitch plate is no longer offeredDidn't IA nix that as being ok?
No, not allowed.Can the detachable rear winch also be used in the front?
Seriously??No, not allowed.
I asked Ineos and was told it is not rated for the load.
Only suitable for towing at low speeds
Which is odd, given that a hitch in the rear is rated for the load.... and the same mounting points it attaches to can also hold a winch....No, not allowed.
I was also told the front hitch is only rated for low speed driving and positioning, which makes sense.Which is odd, given that a hitch in the rear is rated for the load.... and the same mounting points it attaches to can also hold a winch....
You won't regret the wallet pain. They take the cabin to the next level.Thank you fellows! I’m finding funds for my safari windows!
