Thenextchapter
8:57 AM
New Zealand
I have to leave my very much loved Grenadier in the garage for extended periods (sometimes), and looking to maintain the battery while away. Given the EFB and start-stop optimization of our INEOS batteries, looking at the CTEK CT5 as an option. Anyone got any experience with this specific maintenance charger? In a related question, would it be best to connect the charger to a) the auxiliary battery which will charge the starter battery via the CTEK 120S pulse charge feature, b) to the starter battery(see note 1) or c) both starter and auxiliary. This second question maybe for CTEK support, but asking here in case someone already knows the answer. I will ask CTEK as well. Thanks
Note (1). To allow the battery management system (BMS) to correctly determine the State of Charge (SoC) for the starter battery, option b) would have the wiring connected to the jumpstart post in the engine bay.
Note (2). Old reference of CTEK D120 corrected to CTEK 120S.
Quartermaster
Quatermaster Owner
4:57 PM
What is CTEK D120? Isn't it 120 S from factory?
My factory CTEK lets the auxillary battery only charge the starter batterie when this is under ~ 12,3 V, otherwise it is disconnected. So a) wouldn't work (.... to keep the starter full at all times)
Korg
11:57 PM
Warrawee NSW, Australia
I use the Victron charger connected to the starter battery along with a Victron battery monitor on each battery. One app for all devices. Works well.
Thenextchapter
8:57 AM
New Zealand
Ooops, I meant the factory CTEK 120S. Fixed that in the original post.
I think most people will choose option a) as it will definitely charge the starter battery, but let’s see.
Thenextchapter
8:57 AM
New Zealand
I have a Victron smart monitor in my other truck. So, not sure why I did not think of this.:) Nice idea to install one on the auxiliary battery given the dash does not display voltage of SoC for the auxiliary.
Will look into the Victron charger. Thanks
Quartermaster
Quatermaster Owner
4:57 PM
Manual says: trickle charge between 11.5 - 12.6 V of starter batterie, my own observation is 12,3 V . But you will see :)
