Cabin temperature setting not showing
Phred
11:20 AM
Doylestown, PA, USA
When you adjust the temperature knob, at the top of the screen, it gives you the temperature setting.
This morning during ride into work, it wouldn’t show up?? The stereo volume popped up when I changed volume but nadda on adjusting the cabin temp.
Any ideas?
Mine's done that a few times. I think what's worked for me is to perform a soft reset on the screen (guess this is what it's called?): press and hold the mute button in for several seconds (until the screen goes dark), and then press the mute button again to turn back on (can do while the engine is on). Otherwise, when I've turned off the vehicle, left sit for about 10 minutes or more, it was working again when I've restarted the vehicle. Perhaps it's worth sending a note to RDS to document the issue to Ineos? I'll do the same.
Actual time is ~5.5 minutes after being locked; or something around 8.5 minutes unlocked and without opening/closing any doors (y)
All returned on my way home but then XM stopped working?
Returned after the 6 min wait…ugh!
Any ideas?
Thank you for this post since i never knew that there was a digital temperature setting!! I assumed it was just a dumb analog dial setting . The owners manual mentions it when describing the display layout, but not where it describes setting the AC and heat.
The first thing my wife and I did today was to go try it out(y)
